Anyone got a pic of the bottom of the car....
Started by Webby the Bear, 16 May 2012, 22:28:57
Webby the Bear
Quote from: RobG on 17 May 2012, 20:07:08
Quote from: Webby the Bear on 17 May 2012, 20:06:23
Quote from: b4ndit on 17 May 2012, 17:35:15
can take some at work tomorrow if you want let me know what you require :y
That would be sweet, cheers mate! basically a shot/shots covering the whole of the bottom so we can see what sumps are where. for the hg job i've also need to get to remove the ''downpipes''.... not sure what these are although i presume their pipes from the exhaust manifolds   :-\
but anyway, yeah just some shots showing what everythiung is  :y
nice one! ;)
Cheers Rob, where would we be without you?  :-* :y
RIP Paul Lovejoy
Webby the Bear
Quote from: RobG on 18 May 2012, 13:02:43
This any help to you Steve :-\
FEK! I can't see pics at work lol
ill check when i get home. cheers John Rambro  :y
RIP Paul Lovejoy
My garage is a mess, bits of tractor, car, Stihl saws, V8's, Locos the lot.
Thankfuly I have access to other larger workshops!
bored bigyin54
Quote from: Webby the Bear on 18 May 2012, 13:08:31
told you rob had one  ;D ;D
Quote from: Marks DTM Calib on 18 May 2012, 13:13:03
What about bodyshops  :-[
That said, I don't want it in BR blue ;D
Webby the Bear
nice pic rob.... is there a pic for the front end to?  :-* :y
RIP Paul Lovejoy
Quote from: Webby the Bear on 18 May 2012, 20:24:04
You taking the pi$$ ;D ;D ;D ;D
Webby the Bear
RIP Paul Lovejoy
Just had a load of pics (27) :o mailed to me by b4ndit (Terry), will see what I can do Steve. Won`t be tonight though :D
Webby the Bear
no worries rob, i can get the pics.... its the labelling i cant do cos i dont really know what the shizzle is  ;D
RIP Paul Lovejoy
Webby the Bear
and thanks mate, really really helpful!  :y :y :y :y :y :-*
RIP Paul Lovejoy
Webby the Bear
Right chaps, sorry for the HG thread that I probably won't update due to the realisation that I can't simply replace the gasket so this will be left until last....save the most difficult and time consuming best 'til last is the old expression  ::) When I start the strip down I will get to the Thermostat too as that's another job that seems worthwhile.
For now though I think springs, shock absorbers and struts is the next line of fire.
So, I've decided rear shocks 'n' springs is the first thing. I've read Mark's guide about replacing the rear springs...
http://www.omegaowners.com/forum/index.php?topic=90537.0
I've been trying to marry up the pics in the guide with Rob's excellent pic of the rear underside. Now obviously the first thing is to remove those ABS connectors. No probs.
Then as I'm unsure as to where the flexi brake line bracket is on the body can I simply follow the line from the brakes to where it meets the body?
Bit unsure as to where the 4 bolts are securing the subframe to the floor plan..... are these viewable on Rob's piccy?  :-\
The rear shock absorber removal looks a piece of piddle! ;)
Any thoughts greatly appreciated.
RIP Paul Lovejoy
Quote from: Webby the Bear on 20 May 2012, 16:50:42
Above the ABS sensors. 2 bolts to each "U" bracket
