Author Topic: HELP! Coolant issue. Urgent!!  (Read 3492 times)
IainMcDade
  • Bishopton
    • Omega MV6 2.6l 2003
« on: 20 May 2012, 22:46:52 »
Hello everyone, new owner here picked up an omega mv6 2.6 2003 on Friday. So here comes quite a story and i'm sorry, just want to give everyone as much info as possible!!
Was away the weekend so didn't get to drive it much however when i did i noticed the temp gauge wasn't working, or so i thought! Later i was driving about 35mph and noticed the the gauge had began working, temp seemed normal thot mybe a dodgy connection. Then i put the foot down a bit going from a 40mph zone into a national speed limit and approaching 45mph+ the temp started dropping, cruising at 60 it didn't register any temprature as if not even working  :o
So then, later today i was about to wash the car after just getting home, so went to move the car and all of a sudden i saw steam coming from under the bonnet and my friend started shouting saying something was pouring out. Stopped, temp was a bit higher than normal, nothing serious id imagine. So popped bonnet and the coolant cap was loose and coolant had come out from there. Me and my friend both looked everywhere and seems no leeks. Refitted the cap, after topping up with water and left it to cool. Later started it up and drove it and all seemed normal. Temp sat about 80 and car ran fine, however in local town i stopped at some lights and the temp started to rise, never got to high as the lights changed and when i began driving it went down again  ??? Once home i popped the bonnet again and when listening closely i could hear that the coolant cap, which was as tight as can be, was letting air out. It didn't have a perfect seal. I'm taking it down the garage tomorrow to ask my mechanic but any info before then would be great, im not bad with basic mechanics but this kinda puzzles me. Also, i need the car fixed for tuesday for my daily 65 mile commute to work!! So need to get this diagnosed and sorted ASAP!
Like a boss, only better.
    • 530D M Sport, 330i Coupe
Re: HELP! Coolant issue. Urgent!!
« Reply #1 on: 20 May 2012, 22:57:25 »
The coolant bottle can get cracks around the threads where the cap fits, new bottle is approx £30 from a dealers the last time I bought one.
Low running temp is usually down to a stuck thermostat.
« Reply #2 on: 20 May 2012, 22:59:07 »
What VXL V6 says ..........  :y :y
IainMcDade
  • Bishopton
« Reply #3 on: 20 May 2012, 23:10:52 »
Cheers lads, i though thermostat to begin! Then the whole cap popping off just confused me a fair amount wondered if they were related? Possibly just a strange coincidence?
GastronomicKleptomaniac
  • Teesside (the nice bit)
    • 3.2 plod, 2.6 MV6, etc
« Reply #4 on: 21 May 2012, 00:10:10 »
Do we assume from your name that you're from the Scottish Bishopton? :y
PAULCDX
« Reply #5 on: 21 May 2012, 00:17:46 »
Hi Iain,
I had the same problems you are experiencing.............. Check the coolant bottle cap rubber seal as mine was worn away and was allowing coolant to escape from under the cap etc......... Changed the cap and all was fine  :y
Second problem re the temp gauge sounds like you have a thermostat stuck, I had the same symptoms and it turned out mine was stuck.
Once it was changed the temp gauge and heating all worked perfect  :y
Hope that helps.
Paul
IainMcDade
  • Bishopton
« Reply #6 on: 21 May 2012, 07:46:56 »
Yes indeedely matey, take ot your local?
IainMcDade
  • Bishopton
« Reply #7 on: 21 May 2012, 07:49:28 »
Hi Iain,
Hope that helps.
Paul
Happy days, well il get that done today n hopefully all shall be well!
« Reply #8 on: 21 May 2012, 10:51:00 »
Alas not, I'm ten minutes from the much smaller English Bishopton ;)
IainMcDade
  • Bishopton
« Reply #9 on: 21 May 2012, 16:05:48 »
Lol ah well, scottish Bishopton aint big so english must be tiny !  :y
Paddy Flannery
  • Hertford, Hertfordshire
    • 2003 2.6 V6
« Reply #10 on: 22 May 2012, 00:00:11 »
Ian,
When you say you're taking it to the garage, is that your local garage ?
Does Kenny McCanse still work there ? I'm going back many, many years (1983/4) when I used to fly around Bish in a Mark 2 Escort !
IainMcDade
  • Bishopton
« Reply #11 on: 22 May 2012, 10:39:38 »
Hey paddy no not garage in Bishopton as im actually a Renfrew boy so going to a garage there! Its been in and apparently a new coolant cap has cured all the issues! Strange cause i thought itd need a new thermostat but apparently not  ???
Paddy Flannery
    • 2003 2.6 V6
« Reply #12 on: 22 May 2012, 17:18:59 »
Glad it's sorted and I hope your stat is ok. A considerably cheaper fix than a new GM stat !
Page created in 0.034 seconds with 20 queries.
