Author Topic: manta  (Read 2111 times)
pauls
  • By the sea minehead
    • Bmw x3
manta
« on: 23 May 2012, 09:22:02 »
If only I had the money i would like this one  :y 110875799314
custard1
  • southampton
  • its big green and lean
    • 2.2dti
Re: manta
« Reply #1 on: 23 May 2012, 09:26:43 »
I must say what a stunner, my uncle had one of these and can rember the sexy lines of the body work
mantahatch
Re: manta
« Reply #2 on: 23 May 2012, 10:10:04 »
I am stunned, he took a perfectly good auto and converted to manual, the guy is an idiot. There are so few auto Manta's left, I really don't know what to say. Yes it is good he restored it but as for the conversion  >:(
Re: manta
« Reply #3 on: 23 May 2012, 12:25:37 »
Olympia5776
  • Ireland
Re: manta
« Reply #4 on: 23 May 2012, 13:04:24 »
Actually it's a pretty dam' good conversion.
Although I've owned a B series for 36 years I've had , 7 I think , A series too . I built one over a three year period in the early 90's which is still winning shows here in Ireland on which I did that very conversion.
The A series auto came with a 3.44 /1 diff rather than the more common 3.67/1 item. The ratios of the Getrag 240 box suit that diff which gives the same overall gearing as the later B series GTE .
The conversion is simplified due to the fact that the A series auto prop is exactly the length required to fit the longer 240 box and as the original auto gearbox x member can easily be adapted thus the conversion is very easily returned to auto if required.The only other changes required are a manual pedal cradle which bolts in , the clutch cable exit shroud on the bulkhead and the removal of the inhibit switch.
No photos of the interior so I cant see how he finished off the console. The getrag gearlever is further back that the auto but I shortened the linkage by 55 mm which brought the gearstick back to the original position allowing the 4 speed manual console to be used which makes the conversion look stock.
The auto 4 speed gave a direct drive top with ratios and that 3.44 diff making  the car rather lethargic .
Having driven and owned a series auto / 4 speed and 5 speed the latter is by far the better and most suited to modern driving giving a leasurely 70 mph @ 2750 rpm.
Done correctly it enhances the cars driveability and appeal.
mantahatch
Re: manta
« Reply #5 on: 23 May 2012, 13:53:45 »
With all due respect Olympia, it does not 'enhance' it to me. As I said well done for restoring it, and well done to you for creating a show winning car.
That said, how many auto Manta's are still on the road ? very very few I would suspect. I have owned 4 Manta's 2 Ascona's and 1 Cavalier, all B models. Sadly they where all manuals as I just could not find an auto.
