Author Topic: Hid issue  (Read 2694 times)
GmasterT
  • Cambridge
  • does that drifting thing...
Hid issue
« on: 24 May 2012, 00:29:59 »
Hello chaps, friend of mine has a Mfl elite and the left headlight is aiming high (ie the chrome reflector at the bottom is right up against the lens) sadly he lives a fair way away (Swindon) so could only ask him to try things. He said that out felt solid so hopefully isn't an adjuster. Would a failure of a level sensor cause just one light to go wrong though?
Cheers  :y
freecall666
  • looking over your shoulder
    • 2.0l sweat tank on wheels
Re: Hid issue
« Reply #1 on: 24 May 2012, 05:03:01 »
Cheers  :y
the motor can fail on the adjuster for the light try changing it or could be a lose wire on the motor plug could just need cleaning.
Solar charger fitted.
If not Broke dont fix it..
GmasterT
  • Cambridge
Re: Hid issue
« Reply #2 on: 24 May 2012, 19:26:42 »
He tried an old headlight he had, same thing. Ideas?
Re: Hid issue
« Reply #3 on: 24 May 2012, 20:47:06 »
Swap the motors over
GmasterT
  • Cambridge
Re: Hid issue
« Reply #4 on: 24 May 2012, 23:37:19 »
I'm fairly sure he did, as in just took the whole unit out and put the old one in. He said he only plugged stuff in. Also said the t old/test unit started with the reflector about a quarter on an inch of the lens and then it moved close/facing up as per the original problem...
