Author Topic: Stuck in Stokieland  (Read 3272 times)
Stuck in Stokieland
« on: 24 May 2012, 14:13:33 »
Well, here I am, stuck in a layby awaiting Green Flag to take me home :) Alternate light started to flicker, came on steady, but would go out above 2000rpm, then needed 3000, then 4000,now on all the time. No multimeter with me but guessing alternator broke, hopefully just brushes.
Not very hospitable of Staffordshire IMHO.... :(
Re: Stuck in Stokieland
« Reply #1 on: 24 May 2012, 14:23:13 »
You got Daz's number?
« Reply #2 on: 24 May 2012, 14:28:55 »
He's away on a course.... :( Green Flag are on their way.
« Reply #3 on: 24 May 2012, 15:02:55 »
Regulator is the favourite, interestingly the 140A as fitted to the later cars is not quite as robust as the 120A on the earlier ones.
Seem to recall the reg pack being about 30-40 plus a tenner if doing the bearings at the same time
« Reply #4 on: 24 May 2012, 17:18:00 »
Now on my way to some place in Birmingham, they have sourced an alternator and are going to cover the labour cost...  I of course have to pay for the parts......but the job will be robbed....
Darth Loo-knee
  • Death Star
  • Jammie smells of Pooh....
    • TIE Fighter
« Reply #5 on: 24 May 2012, 18:54:23 »
Now if that Lovely Wife of yours had made the trip with you none of this would have happened  ;D
Taxi_Driver
« Reply #6 on: 24 May 2012, 18:57:27 »
I personally would have been tempted to see if i could get home, even with the alternator not working.
Ive driven for over an hour, twice, in the Skudo with no alternator (last time was my visit to stoke two weeks ago when aux belt tensioner let go on the way back), everything turned off.....it made it both times and still had enough juice left in the battery to start it the following morning.  :y
Darth Loo-knee
  • Death Star
    • TIE Fighter
« Reply #7 on: 24 May 2012, 19:01:20 »
Entwood isn't used to modern equipment... Only flying areoplanes  ;D
bertie1.8vectra
  • wolverhampton
  • life is but a dream....
    • Jeep cherokee 3.7
« Reply #8 on: 24 May 2012, 19:05:50 »
Pity I didn't know I'd tried to help out...  :-[
Now to buy shares in BP!!!!!!!!!
« Reply #9 on: 24 May 2012, 20:44:22 »
Hmm. Running loads on an Omega are quite high. Would have had to be a pretty fast dash home. ;)
« Reply #10 on: 24 May 2012, 22:50:08 »
Eventually back home ....
Reasons I didn't want to "risk" running off the battery
Electric fuel pump - I believe the Skudo is mechanical ??
2 X ECU's  .. petrol & gas
admittedly everything else could be turned off... would have been a tad hot ... !! but still not certain how long it would have lasted ...
My other worry ... as the thing was intermittent .. if there had been a sudden "return to function" for a few seconds .. then the alterrnator would be feeding a "flatter" battery than normal, with no back EMF ... this could (?) lead to a very high transient current or voltage surge which might not do all the other electronics a whole lot of good....
So options were fix or ferry home. I expected the latter, but when they sourced the replacement the rule book was half-mentioned .. then they offered to cover the labour costs .. essentially it was cheaper for them to do that than pay a driver to transport me to Bassett then drive back given the distance and the tacho rules ..
Given my committments for the next week or so, it was also easier for me to agree to that than to get home and start stripping the alternator out, then finding the bits to fix it etc etc.
Darth Loo-knee
  • Death Star
    • TIE Fighter
« Reply #11 on: 24 May 2012, 23:52:17 »
At least your home safe and sound Nige :y
« Reply #12 on: 25 May 2012, 02:54:50 »
Diseasals don't require power to run :-\
Sadly us petrolmongers don't get that luxury :'(
Taxi_Driver
« Reply #13 on: 25 May 2012, 06:30:11 »
Ummm.....what about their ecu/cam/crank sensor/injectors etc?? Also the fuel pump on later diesel scudo's is electric (its mounted in the fuel tank, so it doesnt require 'bleeding' if you run out of diesel)  ;)
« Reply #14 on: 25 May 2012, 07:55:32 »
True, but that's a much smaller draw than creating 6 sparks per revolution ;)
