Author Topic: Fault code 430. on a 3.2 MV6  (Read 2098 times)
ted_one
« on: 28 May 2012, 21:03:22 »
EML light came on a couple of days ago,did a quick diagnostic and got a 430 code,this being Catalyst efficiency below threshold, bank2.What I was hoping wether someone can give me some advice as to what's going on, i.e is the Cat on its last legs or is it the Lambda or something else.I tried some Forte fuel treatment and the EML cleared but has since come back on,any advice as usual will be much apreciated :y
Re: Fault code 430. on a 3.2 MV6
« Reply #2 on: 28 May 2012, 21:09:56 »
There isn't really anything wrong. Do NOT change cats for this, move the rear lamdas :y
« Reply #3 on: 28 May 2012, 21:11:16 »
What? You only just got that code Nitro? Come on keep up, we've AAAALL got that one. ;D
Or some of us with 3.2's have. :-\
Very common sadly, not much to worry about though. :)
« Reply #4 on: 28 May 2012, 21:13:57 »
I'm waiting for mine to make an appearance, although still relatively young miles on mine...
« Reply #5 on: 28 May 2012, 21:17:05 »
When I bought the 3.2 I was told "when" that code comes up .. not "IF" that code comes up .... and it does .. regular as clockwork... next time will be in the last week of July, then again around the middle of August .. then it will stay away for a year .. :)
« Last Edit: 28 May 2012, 21:26:57 by Entwood »
« Reply #6 on: 28 May 2012, 21:26:04 »
going by my last 3.2 it will be later rather than sooner for your driving style. Ime anyway...
ted_one
« Reply #7 on: 28 May 2012, 21:38:13 »
Thanks every one for the advice,I'm going to do the drop links in a day or two,so while it's ramped I'll take a look at the level of difficulty in moving the Lambdas,I do'nt weld so It'll have to be subbed out. :y
pscocoa
  • Sandhurst Berkshire
    • Volvo V90 D5 & Grandland
« Reply #8 on: 29 May 2012, 14:53:11 »
Light will go out after 30 starts usually or just reset with Maxscan or similar reader
« Reply #9 on: 29 May 2012, 14:58:34 »
The light will go out when the fault has been fixed.  :y
The fault is remembered for around 20/30 'clean' starts afterwards though ie if you did a paperclip or pedal test it would still be recorded.  :)
