Pages: 1 [2] 3  All   Go Down
Author Topic: check coolant level  (Read 7596 times)
pscocoa
  • Sandhurst Berkshire
    • Volvo V90 D5 & Grandland
Re: check coolant level
« Reply #15 on: 30 May 2012, 11:30:16 »
and mine - but mine took some coolant. Will check again tonight.
Nope - it lost 2 inches out of tank - only done about 24 miles last 2 days since top up. Pressure test tomorrow - cannot see any leak - no oil in water.
not sure why this post happened - can someone delete please - can I not delete post myself?
« Last Edit: 30 May 2012, 11:32:53 by pscocoa »
  • Auckland
    • Mazda MPV
« Reply #16 on: 30 May 2012, 12:49:14 »
Coolant level was fine on mine. If you're going to put a devices in to monitor the cooling system, why make it more fragile than the system it's monitoring? ::)
If you think the Omega's is fragile ....... you've not seen a Senator's or Carlton's  ???. They had the switch in the cap along with a float (that didn't  ::)) and the cap/level sensor was over £30 years ago.
An old Carlton or Senator coolant tank cap makes an excellent pressure tester. :y
I cut the off the part that the float slid up and down which left a hole just the right size to fit a Schraeder valve.
Steve B
  • Leicestershire
    • '52' MV6 3.2 Saloon
« Reply #17 on: 30 May 2012, 20:37:27 »
i put nice new one on today job done  :y :y :y :y
« Reply #18 on: 30 May 2012, 20:56:41 »
An Omega's cap would be far easier to get hold of these days, & you can fit a tyre valve to it.  :y :y
amba
  • Medway towns
    • German V6
« Reply #19 on: 30 May 2012, 21:29:35 »
Does the valve need to be with a piece of inner tube and then sealed into the cap ,or can you just use a valve and seal it in front and back with silicone .
Steve B
  • Leicestershire
« Reply #20 on: 18 March 2013, 12:54:00 »
And here we are 10 months on...check fluid light on again... plug not come out...that didnt last long  :'( :'(
« Reply #21 on: 18 March 2013, 15:43:32 »
Can you take it back on warranty  ???
Steve B
  • Leicestershire
« Reply #22 on: 18 March 2013, 21:27:13 »
Some people on here are retards and wanna try to read proper before slagging off good old vx parts...idiot  :-[ :-[ :-[ :-[ :-[
Broomies Mate
  • Bristol, UK
    • Stuff!
« Reply #23 on: 18 March 2013, 21:38:48 »
 ;D ;D ;D ;D :D
« Reply #24 on: 18 March 2013, 21:39:52 »
ooops ..  ;D ;D ;D ;D ;D
Steve B
  • Leicestershire
« Reply #25 on: 18 March 2013, 22:18:42 »
yes ...what a idiot  :-[ :-[  but i blame you lot..cos nobody told me the omega reminds you when wash bottle empty..... :-[ :-[ :-[
Webby the Bear
  • Northampton
    • 2000 (W Reg.) 2.5 V6 CD
« Reply #26 on: 18 March 2013, 22:22:24 »
is wash fluid the same as coolant then  ::) ;D ;D ;D
RIP Paul Lovejoy
« Reply #27 on: 18 March 2013, 22:29:03 »
Clue might have been in the spelling .....
W A S H. F L U I D  as against those similar words ...  C O O L A N T  L E V E L
 ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D
Steve B
  • Leicestershire
« Reply #28 on: 18 March 2013, 22:35:18 »
yea yea yea ...i had a brake light bulb go too so the screen thing made it priority with the fluid thing behind it ...but at the end of the day.,. :-[ :-[ :-[ :-[ :-[ i need to learn to read  :-[ :-[ :-[
car5car
  • Florida USA
    • 01 Cadillac Catera
« Reply #29 on: 19 March 2013, 14:47:37 »
I disconnected and shorted connector as was suggested by somebody here. Thanks! :y
01 CADILLAC CATERA 3.0 engine (Omega)
Pages: 1 [2] 3  All   Go Up
