Author Topic: engine management light on after changing cat ....  (Read 2134 times)
maverick
« on: 31 May 2012, 19:03:00 »
just a query. I had to change the cat on my 2.2 last year as the flexi joint had broken  >:(  I was warned in advance that it was possible that the management light might come on as I was replacing the cat with a non-vauxhall one. sure enough after a couple of days it did.( code PO420 ) at its last mot the engineer did comment on the light as the car passed the mot with flying colours otherwise including emmisions ... its more of an annoyance than anything else that the light stays on. I've tried clearing the codes but of course it comes back within a day or two ... I've heard theres something that can be put inline with on of the cat sensors and it basically fools the management system into thinking everythings ok. Has anyone else had this problem or tried this solution ?   I imagine there must be as even the newest Omegas are 9 years old now...
ta
Brett
Re: engine management light on after changing cat ....
« Reply #1 on: 31 May 2012, 19:05:31 »
Move the pre-cat lamba to post-cat
maverick
« Reply #2 on: 31 May 2012, 19:09:46 »
and the post to pre ?
Brett
« Reply #3 on: 31 May 2012, 19:12:23 »
Brett
Nope. You`ve got two cats on the downpipe. Pre-cat and main cat. #1 lambda is located manifold side of pre-cat, needs to be moved other side of pre-cat. #2 lambda stays where it is
« Reply #4 on: 31 May 2012, 19:16:16 »
And the pattern cats are universally crap.  If the light wasn't on before this work, its down to the garage to fix. Shit parts have caused this. Simples.
maverick
« Reply #5 on: 31 May 2012, 19:17:28 »
shite prices from vauxhall to start with unfortunately  >:(
« Reply #6 on: 31 May 2012, 19:19:02 »
The garage should have told you you can weld a new flexi joint in for a few quid ;)
« Reply #7 on: 31 May 2012, 19:19:26 »
The cat didn't need changing, thats the sad part. It just needed the a new flexi welded in.  But that involves some element of skill, thus rules out the retards working at most exhaust centres.
« Reply #8 on: 31 May 2012, 19:20:42 »
I do feel for you maverick  :'(
Especially as that place probably won't have your old cat, they would quickly weigh that in, making even more money (£30-50?)
maverick
« Reply #9 on: 31 May 2012, 19:22:47 »
I did ask a couple of places about a new flexi section. but nobody was interested  >:(  as you say probably more interested in cashing in my old one
maverick
« Reply #10 on: 31 May 2012, 19:30:35 »
Rob, when you say to move the no1 sensor from pre to post cat, might sound obvious but is there somewhere for it to screw in ?
« Reply #11 on: 31 May 2012, 19:33:23 »
Nope. This guide is for the V6. Same procedure for you, just one downpipe
http://www.omegaowners.com/forum/index.php?topic=90613.0
