Author Topic: Cam cover help please  (Read 4342 times)
Raymienets
  • Glasgow
    • 2.2 cd & 2.6 LPG
Re: Cam cover help please
« Reply #15 on: 02 June 2012, 12:07:54 »
If its a 2.6 its more than likely to be a male torx bit you need ;)
Cheers Pete yes have them, undid the one on the left hand side but could not see any more but I now understand there are another 5 to be removed. No time today pity as I need to go to work.
  • Auckland
    • Mazda MPV
« Reply #16 on: 02 June 2012, 12:43:08 »
Having seen your photo I think I understand the problem.
Normally the bolts are easy to see down beside the injectors. Your (very neat looking) LPG install has an extra plug & socket fitted to the top of each injector to interface to the LPG install. The extra plugs and wiring are hiding the bolts. I hope the installer made it easy to reconnect it in the correct order.
If it isn't labeled already my first task would be to number them so they go back on where they came off :y
