Pages: 1 2 [3]  All   Go Down
Author Topic: Drop lincs  (Read 16175 times)
Re: Drop lincs
« Reply #30 on: 10 June 2012, 10:11:25 »
As said...If the threads are seized, as they sometimes are, a small angle grinder with cutting disc makes an easier job of removal. They can be a real pig to remove. 18mm ring, and 17 open ended spanner normally, iirc.
cannot find a 18mm spanner, and 17mm will not fit at all, got to find all my tools just put new shed up and nothing in place yet. keeping car off road for a few days till other parts come going to change the wish bones aswell as looking abit old. rubbers are well split.
18 ratchet/socket...?
17 only fits in a certain orientation for the open end of the spanner to fit. Turn with the 18.
Undo and remove the bottom nut, to roll bar, first. Otherwise it moves around and makes the job even more awkward.
got 18mm socket but no room to get it in at top bottom one will,17 will not fit on the center, even with the boot pushed over a bit. no room even to cut it off, orderd new 18mm spanner dont know were ive lost it, new drop link nuts are 19mm with 17mm center,spanner will be here on monday but not driving mig till its all fixed. be driving other car for abit. sure changed them with spanners last time. had shed to bits but not found it must of left it some were.
Never had a problem getting 18mm socket on the drop link nuts, even with a breaker bar - sometimes have to turn them to rotate centre so 17mm open ender will fit.   ;)
getting some new 17mm, and a new 18mm going to have a big sort out and find all my tools, mrs thinks she moved them but she cannot remember were...
Fortunately swmbo dont go in the shed cos of the cobwebbs and spider's , even the dustpan has webbs all over it  ;D ;D
freecall666
  • looking over your shoulder
    • 2.0l sweat tank on wheels
Re: Drop lincs
« Reply #31 on: 10 June 2012, 13:33:14 »
mine not got an spider's in it yet not been up long, but wish she would keep out of the shed :y
Solar charger fitted.
If not Broke dont fix it..
Re: Drop lincs
« Reply #32 on: 10 June 2012, 16:20:31 »
I have a lock on the inside of the shed so any hint shes coming out it gets bolted and light turned off  ;D unless she shouts tea up  :-X Been working hard today and no tea , how you getting on with the drop links ?
freecall666
Re: Drop lincs
« Reply #33 on: 10 June 2012, 16:33:31 »
just waiting for spanners dont want cheap stuff snap them to easy should be here tomorrow, and tie rod on tuesday morning, want all part before i start, buying wish bones on tuesday when get payed so they should be here wednesday- thursday, so should be all here so can be all fitted on saturday, been looking at some new shocks but dose not say what type they are jus says omega 94-02 bright blue for some reason. thinking whats best way to get wish bones off and put new ones on last wish bones i did was on a Granada must be about 8years ago and they were a pain to get off bent the bar., been driving a vectra for a few days and hand brake keep banging when on and rattling when driving dont think its working on drivers side at all so prob have to have a look at it somtime soon.
Re: Drop lincs
« Reply #34 on: 10 June 2012, 22:34:00 »
GM front end parts should last 120k+ :y pattern anything from a week to 40k in my humble experience :y
freecall666
Re: Drop lincs
« Reply #35 on: 11 June 2012, 03:56:25 »
got message back, says they were damaged boxes and dose not know what make they are just omega 94 etc left on them £60 for set, asked why they are blue, said he painted them blue him self anti rust paint so dont think i will get them. :y
freecall666
Re: Drop lincs
« Reply #36 on: 14 June 2012, 22:05:11 »
got one side done, was gone on the anti-rollbar link, tryed to get the steering tie bar off but ends rusted up so getting a new gas can to heat it up so can swap it all over.
then changing the wish bones..
Re: Drop lincs
« Reply #37 on: 15 June 2012, 15:46:30 »
Had hell of a job separating mine ..soaked them overnight in +gas but still solid and even snapped a spanner got them off eventually but took all my strength hanging onto the spanner full weight like a monkey  ::)
freecall666
Re: Drop lincs
« Reply #38 on: 15 June 2012, 23:12:21 »
if it not undo then just going to cut it off and tap it out other side is fine. :y
Clouseau
  • Telford
  • Keeping the dream alive...
Re: Drop lincs
« Reply #39 on: 16 June 2012, 08:58:18 »
Yesterday I did my third wishbone / droplinks change, but first time on the recent car. It was, without question, the most pain in the ar*e job ever, and easily the hardest of the three changes. Don't really know why; the drop links came off easily enough, as did the wishbones, but getting the new ones back in was hell. Fitting the bushes first then trying to force the wishbone down far enough to fit into the steering knuckle just wasn't going to happen.  I finally managed it by fitting the ball joint to the steering knuckle, then fitting the rear bush first before the front one. But getting that rear bush to sit vertically enough in the holder to line up the bolt holes .... flippin 'eck!  I have bruises all over my arms and pulled a muscle in my chest!  However the improvement in the handling is amazing!  Both front bushes were shot, meaning that the car would weave all over the place under acceleration.  Just need to have the tracking re-set now...
Re: Drop lincs
« Reply #40 on: 16 June 2012, 13:46:43 »
 :o
Thats the omega fighting back , took the wind out my sails when i last worked on the suspension  :(
Pages: 1 2 [3]  All   Go Up
