Author Topic: Astra H (mk5) Coolant help please!  (Read 16893 times)
F1 9LFG
  • nr Braintree, Essex
« on: 06 June 2012, 21:05:39 »
Hi all,
Just about to pick up a new car for SWMBO, a 2006 Astra H 1.9CDTI estate to replace an older astra which we currently have.
Now, having researched this car prior to buying it I have found discovered a little problem (well a big one in my eyes)
There is NO coolant temp gauge! (see below pic)
I know the temp can be accessed via the on-board options but this needs setting everytime you turn the ignition on - not ideal.
So I'd like to instal a temp gauge but not a 52mm boy-racer style, more like this
http://www.ebay.co.uk/itm/Digital-LCD-Thermometer-Temperature-Meter-Gauge-C-F-PC-MOD-Water-proof-probe-/330744367539?pt=US_Weather_Meters&hash=item4d01e689b3
But how do I go about the sensor side of things? I'd guess I'd have to drill into the stat housing and screw in a retro sensor? Does anyone know if I can just cut and join the wires to a screw-in type of sensor or is it more involved?
Open to suggestions as somehow I need a constant coolant temp reading viewable easilly while driving.
Can't understand why Vauxhall didn't fit one from the factory - There is a light that comes on when the coolant temp exceeds 125'c but I don't want to wait til my coolant is that hot! at 125'c there is obviously a problem which could have done £'s worth of damage before I'm made aware of it by a little light on the dash!
Thanks in advance
« Last Edit: 06 June 2012, 21:07:45 by F1 9LFG »
waspy
Re: Astra H (mk5) Coolant help please!
« Reply #1 on: 06 June 2012, 21:14:00 »
There's alot of manufactures that don't fit temp gauges. I remember my x girlfiends 1998 Punto didn't have one.
It's called progress or is it cost cutting ::) ::)
F1 9LFG
« Reply #2 on: 06 June 2012, 21:16:59 »
I suspect - but for the sake of a few quid at the most - honestly??!!  >:(
waspy
« Reply #3 on: 06 June 2012, 21:22:16 »
I agree mate. Everyone's doing it. A few quid on a few hundred thousand vehicles is errrr alot ;D
andyc
  • Norfolk
« Reply #4 on: 06 June 2012, 21:45:13 »
Its a complete Can Bus system so you can't cut into the wiring for the other sensors. The sensors in the stat assy run the ecu which in turn run the fans.
If you want to fit a temp gauge then its going to have to be a stand alone system
Andy
Thetford. Norfolk
F1 9LFG
« Reply #5 on: 06 June 2012, 22:09:49 »
Andy
Thought as much  :(
Any idea how I can do this then? Is buying a universal temp sensor and drilling a new hole somewhere possible?
Cheers
« Reply #6 on: 06 June 2012, 22:19:53 »
Cheers
I can't think of another way  :-\ :-\
« Reply #7 on: 06 June 2012, 22:26:54 »
I wouldn't even bother with the hassle to be honest. Enjoy the car, worry about a problem when it arises  :y
F1 9LFG
« Reply #8 on: 06 June 2012, 22:40:26 »
If the car dumps the coolant through a split hose etc I'd only notice when the light came on saying ''I'm at 125'c'', I'd pull over and find I've melted a piston or two...not good.
Maybe this would be better http://www.ebay.co.uk/itm/ScanGauge2-Trip-computer-fuel-meter-scan-tool-for-SMART-/180587708590?pt=UK_Diagnostic_Tools_Equipment&hash=item2a0bddc0ae
F1 9LFG
« Reply #9 on: 06 June 2012, 22:41:48 »
Cheers
No such word as ''Can't'' well so my boss keeps telling me!!
F1 9LFG
« Reply #10 on: 06 June 2012, 22:42:38 »
and google is littered with people stating that a new engine is required after the light came on too late!  :( :o
Brikhead
  • West-Mids.
  • Sleeping. Do not disturb.
    • 2003 chitroen Saxo
« Reply #11 on: 06 June 2012, 23:32:08 »
V.W. have the best 'no temperature gauge' system I've seen, the coolant light stays blue until the engine is up to operating temp...
mantahatch
« Reply #12 on: 07 June 2012, 09:10:34 »
I suppose they are pandering to the idiots. Most people never look at a temp gauge until it is to late. And with todays minimum coolant engines generally speaking the head gasket will have blown or worse before most people will even notice there is a problem.
We run 2 Astra MK5s and you soon get very used to no gauge, bit like the indicators, you might find them a pain to start with but once used to them they are brilliant in my opinion.
« Reply #13 on: 07 June 2012, 10:20:58 »
I like the Astra H lane change indicators, but it seems that Vx have removed them from the current Astra  ??? ???
hoody
  • Scotland
