Pages: 1 [2] 3  All   Go Down
Author Topic: Modeling glue  (Read 6328 times)
Re: Modeling glue
« Reply #15 on: 08 June 2012, 21:13:41 »
Used to use summat called plastic weld :y
Humbrol and Revell both sell polystyrene cement in a liquid for :y should be easily available at any toy shop :-\
MaxV6
  • Oxford UK
    • 2.2SportPremium Jag est
    • Work related forums....
bored bigyin54
  • south wales
    • black beast
Re: Modeling glue
« Reply #17 on: 08 June 2012, 21:15:55 »
if you look in news agents some stock that :y :y
CaptainZok
  • Bolton
  • Victim of Cyberbullying.
    • 3.2 MV6 Estate
TuBy's new whipping boy.
blackviper90210
  • Bromsgrove, West Midlands
    • 03 3.2 Elite Saloon
Re: Modeling glue
« Reply #19 on: 08 June 2012, 22:01:27 »
I use this company for my model kit equipment:
http://www.modelzone.co.uk/
Not sure if any outlets are near you?
HTH's :y
AKA - Mr Bracket
martin42
Re: Modeling glue
« Reply #20 on: 08 June 2012, 22:08:09 »
milton keynes is the nearest and im there every day  :D
blackviper90210
Re: Modeling glue
« Reply #21 on: 08 June 2012, 22:27:22 »
MK was a great place in the 70's & 80's..... ::)
AKA - Mr Bracket
Re: Modeling glue
« Reply #22 on: 08 June 2012, 22:29:27 »
MK was great place before roundabouts were invented, and it changed from a village to a "new town" ...  :(
blackviper90210
Re: Modeling glue
« Reply #23 on: 08 June 2012, 22:31:49 »
Don't forget the concrete cows  ;D ;D ;D ;D ;D
AKA - Mr Bracket
  • Chatham, Kent
    • Ghastly 1.0l Focus
Re: Modeling glue
« Reply #24 on: 09 June 2012, 00:07:41 »
Does anyone know what substitute glue i can use on plastic model kits , i have a 1967 ford mustang to build ...been looking round most shops and cant find a suitable glue and no modeling shops near either . Super glue wont work or general purpose glue  :(
Why won't superglue work? I haven't used anything else for years. Although I now have to buy it, rather than take it off the shelf at work, it's still the way to go. Get both thick, and runny glues(there are several grades in between as well), plus the activator. A light dusting of activator on one part, and a tiny smear of glue on the other, and it's as permanently stuck together as matters on a model. It's quick, cheap and easy. You can't use it on clear parts as it fogs them badly, but the traditional cement is no different.
Use a coating of thick glue, and a spritz of activator as filler. It goes off instantly, and sands similarly to the styrene of the kit. I've a 1/24 slotcar of a Rolls that has superglue filler 2mm thick in places(it was a very poor moulding and badly distorted), and that car hasn't suffered from several 20mph crashes!
Re: Modeling glue
« Reply #25 on: 09 June 2012, 12:39:17 »
Its not the named super glue brand im using so maybe thats the problem ? Cheapo pattern asda super glue but i glued a test piece and left it to dry for about an hour and it just prised apart easily . I thought super glue was an instant bond but its definatley not in this case ... similar for the polypipe as i thought that was ok but it wont bond , maybe i need the proper poly cement  :(
  • Chatham, Kent
Re: Modeling glue
« Reply #26 on: 09 June 2012, 12:47:00 »
Buy 'superglue' from a trade supplier. It will be better and cheaper. You need the activator, it's not optional. Or scrounge it from uPVC window fitters, it's what all the internal trims are stuck on with. I used to buy 1000 big bottles at a time!
Re: Modeling glue
« Reply #27 on: 09 June 2012, 12:51:22 »
Thanks for that i will see what i can find and get on with the mustang re-build  :y a lot of parts in this one that will keep me busy for a while ....i think ill be visiting the proper model shop as i need some paints , i bet they are not cheap nowadays . Only need red and black though  ;)
  • Chatham, Kent
Re: Modeling glue
« Reply #28 on: 09 June 2012, 13:01:35 »
In the same vein, model enamel(like Humbrol) takes ages to go off, and is very difficult to get a decent finish. It's OK for small parts, and detailing but dreadful for bodies.
To do those, get a couple of cans of grey primer from your local pound shop. That's acrylic, and if you use a couple of very light coats first it gives a sealing effect on the plastic. Then you can swap to cellulose aerosols from your favourite motorist shop without having to worry about the solvents melting your project. They give a much better finish, in far less time, and probably less cost. They're the 'right' colours for painting car models. Plus, if you're careful, you can even 'mop' them just like a car paint job, although a polishing bob on a slow Dremel is used.
Re: Modeling glue
« Reply #29 on: 09 June 2012, 23:02:25 »
Found some glue , didnt manage to get to the model shop but used bostic for soft plastics .. in the mustang kit i have a choice of engines to fit , old school with carbs or new with supercharger  :P going old school as i painted the engine block black and have chrome filters and add ons to neatly position in the engine bay . Body looks good with the gloss black enamel i found in the shed . Onto the suspension tomorrow , if only it was the real thing , still taking the time to detail it as if it was  :y
Pages: 1 [2] 3  All   Go Up
