Author Topic: The 200BHP 2.2  (Read 18475 times)
tgm147
  • Wirral
    • '02 2.2 Omega CD
The 200BHP 2.2
« on: 09 June 2012, 23:28:47 »
... We will find out Tuesday to see if I've managed it. I loaded the new engine map on before and wow does it fly now. Will speak to A&M Conversions in Deeside to try and book a rolling road slot in on Tuesday.
Fingers crossed!
Re: The 200BHP 2.2
« Reply #1 on: 09 June 2012, 23:53:37 »
Replaced it with a V6 ...... ?  ::) ::) ::) ::)  ;)
Re: The 200BHP 2.2
« Reply #2 on: 10 June 2012, 08:24:05 »
140bhp to 200bhp from an engine map? To say I'm sceptical is an understatement. But having a 2.2 myself (be it off the road) I'm happy to be proved wrong!  :)
Re: The 200BHP 2.2
« Reply #3 on: 10 June 2012, 09:21:11 »
Unless its had a lot of engine mods or a turbo fitted a remap won't give you 200bhp unfortunately, you might get another 10% or so
Re: The 200BHP 2.2
« Reply #4 on: 10 June 2012, 09:57:43 »
With a supercharger bolted on ....sorted  :y
tgm147
  • Wirral
    • '02 2.2 Omega CD
Re: The 200BHP 2.2
« Reply #5 on: 10 June 2012, 10:07:27 »
A few other things have been done too - ported and polished inlet manifold and throttle body, fuel pressure raised and a smoother flowing exhaust. It last made 181bhp on the rolling road on a stuffy hot day.
Re: The 200BHP 2.2
« Reply #6 on: 10 June 2012, 10:20:39 »
Still can't believe those figures, not with such light mods. The Z22YH which was direct injection did 153bhp out of the factory
tgm147
  • Wirral
    • '02 2.2 Omega CD
Re: The 200BHP 2.2
« Reply #7 on: 10 June 2012, 10:32:18 »
Re: The 200BHP 2.2
« Reply #8 on: 10 June 2012, 10:35:40 »
Re: The 200BHP 2.2
« Reply #9 on: 10 June 2012, 10:55:36 »
Take it too 2 or 3 other rolling roads & take the average, bet you will get different results
Re: The 200BHP 2.2
« Reply #10 on: 10 June 2012, 11:09:15 »
You will get different results, you'd get a different result on every single rolling road you took it too, however, this one said he had 180.9 BHP so he did make pretty much 181 BHP :y. That's an absolute cracking figure without a turbo on that engine!
Re: The 200BHP 2.2
« Reply #11 on: 10 June 2012, 12:01:50 »
I don't agree. The rolling road says it reached almost 181 BHP but who says the rolling road is correct. Its common knowledge that rolling roads are often set to show greater output ::)
Omega_Dan
Re: The 200BHP 2.2
« Reply #12 on: 10 June 2012, 12:08:33 »
There are a few astra 2.2's on the forum running around 190bhp :y. With the modifications on mine its running approximately 155 bhp.
Re: The 200BHP 2.2
« Reply #13 on: 10 June 2012, 12:13:28 »
Astra 2.2 lump though is totaly different engine  :y
Omega_Dan
Re: The 200BHP 2.2
« Reply #14 on: 10 June 2012, 12:24:30 »
I did think the heads were a bit different but I was assuming they would be the same. Wrong again  ;D
Pages: [1] 2 3 4  All   Go Up
