Author Topic: V6 elite wont start  (Read 4424 times)
D3f1anCE
  • kent
    • 97 omega 2.5 v6 auto
Re: V6 elite wont start
« Reply #15 on: 18 June 2012, 14:13:26 »
I'm on my own so I can't really see anything
D3f1anCE
  • kent
« Reply #16 on: 18 June 2012, 14:14:07 »
I'm on my own so I can't see anything
Brikhead
  • West-Mids.
  • Sleeping. Do not disturb.
    • 2003 chitroen Saxo
« Reply #17 on: 18 June 2012, 20:12:34 »
I could be massively wrong.... But to be honest it just doesn't sound the way it normally does when I turn the key.... All I can hear is a loud whirring
What can you see moving under the bonnet when someone else turns the key?  ;) ;) You're looking for the crank pulley to spin as above.  :y :y :y
The crank pulley will still spin even if the cam belt is totally snapped...
« Reply #18 on: 18 June 2012, 20:14:39 »
What can you see moving under the bonnet when someone else turns the key?  ;) ;) You're looking for the crank pulley to spin as above:y :y :y
I know ......  ;)
« Reply #19 on: 18 June 2012, 20:28:41 »
Which will prove that the bottom part of the engine is turning .. ie .. the starter is achieving something at least ....... if the bottom half is stationary ....... its nowt to do with cambelts !!
D3f1anCE
  • kent
« Reply #20 on: 18 June 2012, 20:30:08 »
Finally got someone to turn it over whilst I checked pullovers and can belt and all is still turning over.... Please excuse my dumbness I'm secretly a blonde... So with the fault code I list earlier.. What u guys reckon it could be and can any body supply me with a replacement ?
« Reply #21 on: 18 June 2012, 20:34:55 »
See reply #12  ::) ::) ::) Crank shaft sensor  :y  and buy a genuine sensor & not a pattern/generic part
« Reply #22 on: 18 June 2012, 20:39:55 »
« Reply #23 on: 18 June 2012, 20:40:55 »
Don`t forget reply #1 ;) ;D
D3f1anCE
  • kent
« Reply #24 on: 18 June 2012, 21:29:08 »
Cheers guys...much obliged :p
« Reply #25 on: 19 June 2012, 13:33:39 »
Are you looking at the cam belt or the auxiliary belt? If its the belt you can see without removing anything, its the auxiliary belt.
