Alternator Failure
Started by Andy H, 17 June 2012, 23:59:02
Can get a S/H one couriered tomorrow, Bosch 120A
Quote from: adey2 on 18 June 2012, 02:29:18
was he in a service van or not, did he have a stowaway or dont you know, eu laws are only if the vehicle fitted with a tacho, you allowed to run 60 miles from base without a tacho disc or card inserted or if you have card or disc in your allowed to run outside if tacho laws run to, think he was one of the lazy gits that seem to pop up who couldnt be arsed to rear load your car due to being auto then mess around to lock steering in place with straps and tow you whole distance, id be logging a complaint, i used to do the job so know rules and he having you over, aa were renound for sending patrols all over just to do a wheel change, one lad i know went 150 miles
I think both AA No1 & AA No2 were 'service vans' they were half filled with an enormous tool chest & I think that the rear half was filled by the towing dolly. I didn't discuss tachos with AA No1 or No2 but the recovery lorry driver (AA No3) that took us home had to take a break on top of his 1.1/2 hour drive from Plymouth which is why we spent 2 hours sitting in a supermarket car park.
I wouldn't have been happy towing my (automatic) Omega tail first because there is bugger all ground clearance under the front and it has so much overhang that lifting the rear would mean shaving the front spoiler off.
AA No1 had an official looking laminated sheet showing his permitted range and he appeared to have some idea of the range of the other drivers who were on shift. All 3 drivers commented that they were surprised that no other vans were available so assumed that 'something big' must be going wrong on the M5 :-\
Quote from: RobG on 18 June 2012, 10:10:15
Thanks Rob. I won't be in tomorrow as driving SWMBO to Exeter (in her car). Couriers can never find our house so I usually spend 1/2 a day on internet & then phone trying to track a parcel that is recorded as 'delivery refused by customer'  >:(
Quote from: allen25 on 18 June 2012, 10:07:27
Best of luck with it. I do remember £180 though, although it was a couple of years ago. If you are doing the job yourself, there is a recyclers network for used alternators etc, bit of a risk of course but may get you up and running. New one is best but let me know if you need the links.
I can't log on to Trade Club at the moment to check the VX price, I guess someone has been trying to use the old password >:(
The alternator on my previous Omega died at a similar mileage (158K) & I fitted a reconditioned alternator from a Bosch Service Centre. That was about 5 or 6 years ago & I think it cost me £180 then.
April 2011 TC prices
R1530055 140amp £170.90 + VAT
R1530056 120amp £96.38 + VAT
You could always just fit new bearings and a regulator pack yourself, probably change from fifty quid then
Quote from: Marks DTM Calib on 18 June 2012, 12:26:21
I would have done that with my previous car but I couldn't track down a supplier :(
If someone can point me in the right direct I would extremely grateful :y
Bearings can be got from simply bearings.
The regs are available via the bay of e.
You need your alternator off to get the type number to match the reg up.
Excellent :y
Alternator should be on the bench very soon (just as soon as I can remember how I got the last one off ::) )
Bagpipes off, disconnect battery, Aux belt off, two bolts, pull alt. forward, disconnect wires
It's out.  :) Started off by unclipping header tank and removing air filter but the bagpipes had to come out at the end to leave a big enough opening to pass the lump through ;D
Regulator is different to the last one I had (which was the same as in the maintenance guide) with the corroded spring connector.
This one is all nuts, screws & washers. No spring contact.
