Author Topic: Replacing wiper blades: How to...  (Read 4075 times)
Webby the Bear
  • Northampton
    • 2000 (W Reg.) 2.5 V6 CD
« on: 18 June 2012, 09:44:34 »
Hi guys,
As above, driving back from Chris's yesterday, the Heavens opened. Luckily not for long as my wiper blades were useless; just smearing rain water and other crap across the screen  ::)
So. Time to replace and luckily I have time off and some Bonusbond vouchers so Hellfrauds it is today.
I've never replaced these before.  :-[ Is it the same as in this video from ETCG?
http://www.youtube.com/watch?v=mFo1bDbbLKw
Cheers :)
RIP Paul Lovejoy
Re: Replacing wiper blades: How to...
« Reply #1 on: 18 June 2012, 09:55:54 »
Hi guys,
Cheers :)
I had the same problem a while back steve and replaced with flatblades , never had any trouble since . Although fitted myself which is basically clip on fit mr hafraud will fit them for you for a fee  8)
« Reply #2 on: 18 June 2012, 10:06:09 »
Yes, but you can change them when in their parked position  :y  :y
SMD
  • London
    • :( nowt
« Reply #3 on: 18 June 2012, 10:46:14 »
I changed mine a week ago with GM ones and they work quite well. It didnt rain for nearly a week after  ;D
I didnt have to be quite as brutal as Eric. I just swung the wipers in the 'T' position and just pushed the blades down and around (there was no tab to push in). Fitting is obv. the reverse.
Webby the Bear
  • Northampton
« Reply #4 on: 18 June 2012, 10:49:20 »
Cheers guys.  :y
RIP Paul Lovejoy
Webby the Bear
  • Northampton
« Reply #5 on: 18 June 2012, 12:03:17 »
Well that was a piece of urine!!!  :y
RIP Paul Lovejoy
« Reply #6 on: 18 June 2012, 12:13:56 »
Good , now we are sure to get non stop sunny weather  ;D :y
Webby the Bear
  • Northampton
« Reply #7 on: 18 June 2012, 12:21:50 »
More than bleeding likely! As it's nice today I'm just about to start removing Ralf's front leg  :D
RIP Paul Lovejoy
« Reply #8 on: 18 June 2012, 15:17:26 »
If it gets to be a pita use the hacksaw method ..ralf wont feel a thing  :P Just done a few jobs on mine seeing as it was sunny , 4lb of weight removed from the front of the car  :o
« Last Edit: 18 June 2012, 15:19:32 by EMD »
Webby the Bear
  • Northampton
« Reply #9 on: 18 June 2012, 15:26:54 »
Well, I'm beat for the day. Stuck again on one screw that refuses to budge. give us 2 ticks i'll post the pics.... may have also broke a component in the process. not broken as a result of a strop i might add.... just i gave a bit too much... erm... leverage  :-[
RIP Paul Lovejoy
« Reply #10 on: 18 June 2012, 15:38:33 »
Never replaced a leg but will be interesting having a look at the pics ..
Webby the Bear
  • Northampton
« Reply #11 on: 18 June 2012, 15:38:41 »
Right, here we go :
And then I removed the torx bolt from the speed sensor and was gently (I promise) trying to prise this out as I thought it was stuck due to rust..... then boom, it snaps in half..... but hey, thats why i bought ralf  :y
RIP Paul Lovejoy
« Reply #12 on: 18 June 2012, 16:11:00 »
Oooer , i think that should have popped out with a wriggle  :-\
Webby the Bear
  • Northampton
« Reply #13 on: 18 June 2012, 16:12:44 »
That's what I was thinking  ;D As I said, this is why I bought it to practise on  :y
RIP Paul Lovejoy
« Reply #14 on: 18 June 2012, 16:15:12 »
Did you get flat blade wipers , martin recomended them a while back so put them on mine and jobs a good en  :y
