Pages: 1 [2] 3  All   Go Down
Author Topic: Key fob has stopped working  (Read 7637 times)
Re: Key fob has stopped working
« Reply #15 on: 19 June 2012, 17:45:26 »
Just wondered cos I've read some frightening stories about alarms and powersounders going off and even damaging the car etc  :o
Tend to give you the little warning chirps..................ignore at your peril
PAULCDX
« Reply #16 on: 19 June 2012, 17:54:12 »
Ummm I certainly won't be ignoring that then.
Once the battery is changed and hopefully fob working, will any alarms go off or anything need re-setting, sorry if I'm being stupid  :D  ;D
allen25
  • Worcestershire
    • Omega 2.6 V6 2001
« Reply #17 on: 19 June 2012, 18:12:10 »
From my experience, and it looks like your model is only a few months from mine you should be able to sort it from the details posted (hopefully). If the buttons on your remote are ok and you replace the battery (if that is the issue) you may get away with the VX instructions, position 2 etc. If you do that's great news. No problem with driving it, locking and unlocking manually and don't worry about the alarms, they wil be completely normal after you've sorted the issue. My comment re the alarms is that on our models, if you unlock using the key, if you are not expert at the timing (done it loads of times) the alarm will go off every time you open it! Cheers.
allen25
  • Worcestershire
    • Omega 2.6 V6 2001
« Reply #18 on: 19 June 2012, 18:33:18 »
Also, I meant to say, there is a manual boot release handle. If you've not needed it before, you can find it by going into the back seat, kerb side, drop the seat and reach in. It is a pull cord (with handle) mounted on the underneath side of the boot lid. Hope this helps!
PAULCDX
« Reply #19 on: 19 June 2012, 18:39:45 »
Thank you so much for your help, will update once fixed  ;D  :y  :y
PAULCDX
« Reply #20 on: 19 June 2012, 18:55:35 »
Battery has now been changed and the key still won't work  >:(
I've tried the re-sync and still no buttons work etc...........
Do possibly have a faulty fob or could there be a blown fuse in the car that works the key etc?
Thanks
Paul  :y
« Reply #21 on: 19 June 2012, 18:57:54 »
Fuse #20 is for C/L
The Red Baron
  • burton on trent.staffs
    • 2000 chipped mv6 3.0l
« Reply #22 on: 19 June 2012, 19:01:16 »
tis possible the battery carrier has come away from the pcb. ;)
PAULCDX
« Reply #23 on: 19 June 2012, 19:01:52 »
So shall I try changing this Rob and then see how I get on? Should my key be working the boot with this fuse?
PAULCDX
« Reply #24 on: 19 June 2012, 19:03:02 »
Will prob just send Key to Martin and see if it's gone faulty etc......
Cheers Guy's
« Reply #25 on: 19 June 2012, 19:05:48 »
Try fuse as first port of call but as Jon says, could be a dicky PCB/battery carrier or microswitch. Split the fob, have a gander, then try pressing the microswitch/es without the fob cover attached.
allen25
  • Worcestershire
    • Omega 2.6 V6 2001
« Reply #26 on: 19 June 2012, 19:10:29 »
I don't think it is down to fuses, but thats only my spin. When you take the key fob apart, what condition are the buttons in. Do they still have rubber 'pushes'. When they really wear out, they drop off and that's just about the end of it! The VX instructions do say that after a short period of time, if the battery is not replaced then re-coding may be necessary. It's worth sorting out though. If you use a vauxhall dealer you will need the car pass. The code they need is on there. If you don't have a car pass then they can get it for you but unfortunately you have to pay for that service! If the buttons are wrecked, You're really stuffed because when your new fob arrives it will almost certainly need reprogramming to your car! Not the end of the world though. Hope you sort it!
« Reply #27 on: 19 June 2012, 19:15:01 »
You get a member on here (Martin Imber) to replace them, simples :y
PAULCDX
« Reply #28 on: 19 June 2012, 19:22:21 »
Just find it strange how it worked the other week and now it has stopped?
Wouldn't be down to us messing with the interior / door cards being changed etc?
Car was been left unlocked for weeks cos the battery died in the car and was left on the drive. Today car was jump started and all was fine on that front until I came to try and lock the car?
Any coincidences here??
Either way I will now send the Key to Martin to check over.  :y
allen25
  • Worcestershire
    • Omega 2.6 V6 2001
« Reply #29 on: 19 June 2012, 19:32:25 »
Banging on about it I know but the key fobs and batteries do wear out so that's probably it in combination. Our member might have a value solution! Unfortunately I used the dealer (don't use them for anything else other than genuine parts - but they are happy with that). But you'll be well happy once it is sorted.
Cheers JA
Pages: 1 [2] 3  All   Go Up
