Author Topic: WINDSCREEN WASH TANK LEVEL SWITCH  (Read 1726 times)
LFF64
  • HADDENHAM BUCKS
    • 64 insignia CT Nav 4x4
« on: 20 June 2012, 09:05:51 »
I have a problem that keeps happening or rather doesn't The level switch does not tell me when the tank goes empty .
I have had the switch out and it is switching when I test it on the bench the switch looks to be in good condition and then when reiftted in the empty tank it works and puts the alarm up and when the tank is refilled the alarm goes off .
Any ideas or is it just replace the switch  :y
Re: WINDSCREEN WASH TANK LEVEL SWITCH
« Reply #1 on: 20 June 2012, 10:34:15 »
There's not much to not work, so I'd replace it & go from there.  :y
« Reply #2 on: 24 June 2012, 22:45:03 »
If the switch tests ok, which it sounds like it does, it could be worth starting with the plug :-\ Check it for condition, easy enough to chop in a new one if needed :y
