Author Topic: changed crankshaft sensor but still wont start  (Read 4224 times)
Re: changed crankshaft sensor but still wont start
« Reply #15 on: 25 June 2012, 14:58:46 »
It's well known on here that pattern sensors are shite. Maf code is common with crank sensor fault.
Fit a GM genuine sensor from a dealer. Used no good either as they can't be removed from the oil pipes without damage.
Must be new, genuine, vx, from a dealer.
But you may well be asked which plug shape the car has. They can't tell from the system so take the pattern one with you. It's got to come off anyway.
« Reply #16 on: 25 June 2012, 23:48:44 »
Fit genuine Vx crank sensor mate - pattern are at best krap ;)
beany
« Reply #17 on: 27 June 2012, 23:04:09 »
You guys are very cool! :-) Fitted a genuine part and it worked just as you said it would. Thank you all for very informative advice. :) ;D 8)
adrian007
  • stoke
    • omega
« Reply #18 on: 01 July 2012, 16:11:12 »
could anyone explain to me how to fit a crank shaft sensor on a omega ??
SIR Philbutt
  • Rochdale - Manchester
    • 03 2.2 CDX LPG estate
    • PJB Home Services
« Reply #19 on: 01 July 2012, 16:34:48 »
follow this link for everything you ever need to know about everything  :y
http://www.omegaowners.com/forum/index.php?board=12.0
then go in gen disc to find out about everything else  ;D ;D ;D
« Reply #20 on: 01 July 2012, 17:43:41 »
And if you get stuck,you have an Omega expert living on your doorstep. Known on here as Darth Loo-knee. ;)
