Author Topic: rather Astra !!!! ARGHHHHHH  (Read 21407 times)
freecall666
  • looking over your shoulder
    • 2.0l sweat tank on wheels
Re: rather Astra !!!! ARGHHHHHH
« Reply #15 on: 29 June 2012, 23:55:37 »
just been looking around and there was a few problems witht ecu's on them with water getting in them, abs light flashing speedo failing the list go's on, says the rubber seals just fail on them and water gets in, says on vx site that should replace the seals and the ecu. some models lights stop working and dash. and this is just faults reported.
Solar charger fitted.
If not Broke dont fix it..
« Reply #16 on: 30 June 2012, 12:36:07 »
Where?
freecall666
« Reply #17 on: 30 June 2012, 15:01:44 »
Where?
vx astra club. sport club. vauxhall data files astra repairs.
« Reply #18 on: 30 June 2012, 16:01:22 »
Can you provide a ref, as I can't find it :)
freecall666
« Reply #19 on: 30 June 2012, 16:50:12 »
you should find the vauxhall astra data files repairs its on the garage site and manufacture, its on there data list you will need to log in with your details. look under 2001- 2005 astra report logs. other sites you need to log into as well, cannot link to this site cannot even copy and paste nothing comes up on here or in note pad so think its locked
freecall666
« Reply #20 on: 30 June 2012, 17:07:48 »
also its in german not english will need transater if you dont know german  :)
freecall666
« Reply #21 on: 30 June 2012, 17:51:47 »
just been looking more into it and says egr fail and wiring to ecu.
shell petrol seam to sort out most problems ( this is custumers report after fault was not fixed about 30 custermers) no fault code stored
coil pack and wiring faults with single misfire.
random fault codes, garage reports that taking off battery from an hour has help with the fault codes when battery is refitted and fully charged. and list pointed to egr fault and ecu wiring.
another one was vibration effecting the ecu.
evpa vale sticking.
ect circuit fail in ecu.
engine temp sensor and wiring.
and ecu failed, and sent to repair and found no faults with it, put back on and then there is no faults stored.
ecu rubber seal and corroded pins on plug.
ecu turning off injectors, (tec) say ecu thinking they are cloged up or low fuel turning them off.
fuel sensor incorrect signal faulty wires.
low fuel level misfire, ( garage tec advied not to run on red line, and keep fuel level above this) also this caused multiple cylinder misfire.
« Reply #22 on: 30 June 2012, 18:14:58 »
I have access to GM's technical library. A doc ref will do. Thanks.
freecall666
« Reply #23 on: 30 June 2012, 18:37:54 »
has no ref number its dates 2001-2005. then another page 2005-2010 date and garage code is only. fault enquiry page.
« Reply #24 on: 30 June 2012, 18:50:52 »
Is it a GM doc?
freecall666
« Reply #25 on: 01 July 2012, 01:49:48 »
Is it a GM doc?
think its a systerm linc doc its dose not use explora it use the softwear from a bit of kit i picked up, screen on it is damaged so have to use it on my pc with it pluged in, has account loged in it. dont know how old it is but works on pc cannot get a new screen for it as been well used and has no info on back bar for security code. only seams to cover from 2000. have tryed downloading in pdf but keeps asking for password but dont know the pasword.
« Reply #26 on: 01 July 2012, 09:10:39 »
So its not a GM doc then...
MaxV6
  • Oxford UK
    • 2.2SportPremium Jag est
    • Work related forums....
« Reply #27 on: 02 July 2012, 19:41:33 »
Hmm   seems likely to be ECU related ,   looking in to replacements.....  rather ouch.
MaxV6
  • Oxford UK
« Reply #28 on: 02 July 2012, 19:42:50 »
apparently there's a Vx ECU wizard somewhere around Milton Keynes.....   working from home/out of his shed/garage ,  has anyone encountered such chap and have his contact details??
Brikhead
  • West-Mids.
  • Sleeping. Do not disturb.
    • 2003 chitroen Saxo
« Reply #29 on: 02 July 2012, 22:16:24 »
How have you confirmed this?
This is who I use, they are quite a large outfit...
http://www.atpelectronics.co.uk/
Page created in 0.026 seconds with 20 queries.
