Author Topic: Climate Control  (Read 1874 times)
m.ian
Climate Control
« on: 02 July 2012, 22:05:46 »
OK,
So engine temp at 90, outside temp gauge says 15c and CC set at 25c and all I get is cold air out of the vents.
Question is there anything I need to reset or can check as this does not seem right?
horsecow
  • Omagh
    • 2.2 dti cdx/3.2 elite
Re: Climate Control
« Reply #1 on: 02 July 2012, 22:11:09 »
Is it cold air from both sides passenger and driver or just one side?
Drive 'er like yer late for mass!!
Re: Climate Control
« Reply #2 on: 02 July 2012, 22:11:36 »
Take the vacuum pipe of the top of the HBV and block the end of the pipe with a small bolt/screw .. leaving the HBV open to atmosphere and see if that makes any difference.
HBV can "stick" in the no heat position, this seems to sort it out, or the climate is giving a vac signal when it shouldn't be .. :(
No vac to HBV equals heat to matrix.... vac shuts the hot water off
m.ian
Re: Climate Control
« Reply #3 on: 03 July 2012, 18:57:42 »
will give that a go, if and when the rain stops :(
birdman
  • Chepstow
  • one volunteer is better than ten pressed men
    • 03 2.2petrol gls estate
Re: Climate Control
« Reply #4 on: 06 July 2012, 20:37:26 »
you might need to wait untill the winter!! :D
