Author Topic: Cheapo Opel tech 2  (Read 6575 times)
iggy21uk
  • Berkhamsted - Herts
  • Omega Spotter -  tats gone tanning
Cheapo Opel tech 2
« on: 29 October 2006, 16:50:39 »
Is this the home of the software that comes with the Cheapo Opel Tech 2 ???
If so appears to be a later verson ???
Not able to try it a I don't have one.
http://www.vezerdiagnosztika.hu/index_en.html
[size=10]Opelscanner Can owner / Cam lock kit owner [/size] [/i][/b]
Re: Cheapo Opel tech 2
« Reply #1 on: 29 October 2006, 16:57:34 »
Looks like it is the version thats sold for Ł500. Maybe someone with cheapo lead can confirm?
Taxi_Driver
« Reply #2 on: 29 October 2006, 17:00:49 »
No, thats a different one and at 750 euros not cheap!
The download link is only an upgrade so not worth downloading unless you already have one and orig software
« Reply #3 on: 29 October 2006, 17:02:58 »
The download worked and installed for me, didn't have original installed. Seems to run, though says can't find interface when I go to diagnose something (coz I ain't got an interface)
Taxi_Driver
« Reply #4 on: 29 October 2006, 18:25:35 »
Oh Didnt work for me  :-[ I'll have another go......
Taxi_Driver
« Reply #5 on: 29 October 2006, 18:55:25 »
Had another go....worked this time for sum reason....
However it doesnt work with the cheapo tech2 interface, well not mine anyway......just says carnt find interface......even tho i set it to use com1 and interface plugged into diag socket.
Checked the hungarian software and that worked, got.....
ECU Sikeresen Inicializálva.
Keyword 2031 protokol
Keyword #1: EF
Keyword #2: 8F
systemSupplierSpecific: L
Alvázszám: W0L0VBM3531102934
OPEL alkatrész szám: 24426542 DG
Gyártó alkatrész szám: SIE  0116004000
Gyártó ECU szoftverszám: 6586115108
ECU Szoftververzió: 0800
ECU tipusbizonylatszám: S01003
ECU motor típus: Z22XE
RepairShopCodeOrTesterSerialNumber: S000304669
ProgrammingDate: 20060809
CalibrationRepairShopCodeOrCalibrationEquipmentSerialNumber: 161D
CalibrationDate: O10D101C
CalibrationEquipmentSoftwareNumber: L2CD100A
ECUInstallationDate: 6586055204
VehicleManufacturerSpecific: 3200
Tárolt hibakódok vannak!
P0340  Nincs jelen
( 8 )  <Ismeretlen DTC>
P1700  Nincs jelen
( 0 )  <Ismeretlen DTC>
P0170  Jelen van
( 2 )  <Ismeretlen DTC>
No suprise with the fault codes  :(
Dunno if you can tell from that Jaime what version of my Engine ECU is at......carnt read the g/b ecu anymore  :(
« Reply #6 on: 29 October 2006, 19:05:35 »
Set interface to COM1 (or whatever) click Apply, then Back, then back in to Settings, then Test.
What happens then?
Taxi_Driver
« Reply #7 on: 29 October 2006, 19:10:39 »
What happens then?
First off it was saying carnt check usb.....
Then after i had set it to com1 done apply etc....then done test, it just said it couldnt find interface......so as the usb whinge had gone away....i guess i had set it correctly but it still wouldnt play ball
« Reply #8 on: 29 October 2006, 19:12:59 »
Proper COM port or usb adapter...
Taxi_Driver
« Reply #9 on: 29 October 2006, 19:14:58 »
Proper com port.......dell laptop plugged into port replicator gives me a com port.
« Reply #10 on: 29 October 2006, 19:17:49 »
Hmm, dunno without have a play myself.
