Author Topic: My missus WILL kill me!!  (Read 6227 times)
Essex_Andy
  • Have a guess?
« on: 28 October 2006, 21:28:35 »
Where I bought the new n/s headlamp today they had a set of 3.0 cams for £100..........guess what is sitting next to the 3.0 polished and modded throttle body, new cam cover gaskets and o-rings and camshaft seals?!?!?!?!??!?!!?
Next payday or possibly in the new year I'm going to get a cam belt kit and FSE boost valve. If possible looking for helpers to get this project finished.
Breakfast, lunch (and supper if need be) stellas and JD on me
If an artic overtakes you, you're driving too slow!!!!!!!!!!!
Re: My missus WILL kill me!!
« Reply #1 on: 28 October 2006, 21:36:36 »
I would like to help Andy but im useless with spanners and I live miles away. Sorry
Timbuk
  • Telford
  • owned a Datsun 120y once!
« Reply #2 on: 28 October 2006, 21:40:25 »
Your only interested because the word Stella appeared :D
« Reply #3 on: 28 October 2006, 21:43:30 »
Stella, JD and breakfast :y
Essex_Andy
  • Have a guess?
« Reply #4 on: 28 October 2006, 21:47:26 »
[quote ]
Stella, JD and breakfast :y[/quote]
The building blocks for a great day :)
Timbuk
  • Telford
« Reply #5 on: 28 October 2006, 21:50:15 »
Correct ;)
Timbuk
  • Telford
« Reply #6 on: 28 October 2006, 22:02:28 »
How about this then EP
Plan A :- Get Mark to do some cams, get Robin Hood to make a DVD of it. Buy DVD. Tell Mrs EP your going to Santo Podi, pick me up on way( although you would have to sort out that dodgy aeriel first) drive down to Essex, help Andy, Hey Presto....... Stella JD and Breakfast :y
Plan B :- Stop Dreaming ::)
« Reply #7 on: 28 October 2006, 22:38:39 »
From the measurements I did today......the 3.0 and 2.5 throttle bodies have the same size butteflys....
Essex_Andy
  • Have a guess?
« Reply #8 on: 28 October 2006, 22:43:54 »
It cost me a whopping £30 and I took my little polishing mops to various bits...not too smooth as I believe a bit of turbulence is good. Not sure if I was having my leg pulled but the 3.0 item is a slightly larger bore? ? ?
« Reply #9 on: 29 October 2006, 00:15:58 »
I will start packing my tool kit (hammer and screwdriver) :y
Timbuk
  • Telford
« Reply #10 on: 29 October 2006, 00:30:41 »
Take it you've borrowed the screwdriver ::)
« Reply #11 on: 29 October 2006, 00:37:49 »
I got it using my Greenshield stamps ;D
CaptainZok
  • Bolton
  • Victim of Cyberbullying.
    • 3.2 MV6 Estate
« Reply #12 on: 29 October 2006, 00:43:24 »
Reminds me of a foreman fitter where I used to work.
He had a toolkit that was arranged in weights from toffie to sledge and a screwdriver made from a bit of power hacksaw blade ground down and wrapped in insulation tape for a handle.
I was told this guy used to work on Spitfires during the war, "Who for I asked the bloody Luftwaffe?"
TuBy's new whipping boy.
« Reply #13 on: 29 October 2006, 00:44:38 »
;D ;D ;D
omegaV6CD
  • Darlington
« Reply #14 on: 29 October 2006, 00:48:42 »
FSE valve will be an absolute waste of money, if you are desperate for extra pressure get a standard 3.8 regulator from a saab v6 or a 2.6omega etc, it should be cheaper and straight forward to fit. Personally i wouldn't bother though, there is no much gain.
