Author Topic: Electrical Relays  (Read 1940 times)
Michael2.6
  • Bishop Auckland
    • Vauxhall Omega
Electrical Relays
« on: 06 July 2012, 08:32:45 »
Anybody no which relay it is that works the self levelling suspension motor.
Re: Electrical Relays
« Reply #1 on: 06 July 2012, 09:34:58 »
It's in the panel next to the fuse box,left hand side. Left hand one, main beam, S/L other one. Both the same
« Reply #2 on: 06 July 2012, 09:48:58 »
Unless its TBE, where the relay lives in the glovebox ;D ;D
What RobG says is correct.
You got a failure? IME, its normally an ECU/sensor failure (assuming you cannot communicate with ECU).  Note, pre 1998 ECUs are incompatible with post 1998 ones :)
Michael2.6
  • Bishop Auckland
    • Vauxhall Omega
« Reply #3 on: 06 July 2012, 11:01:33 »
Hi TB
If it was a sensor failure it would bring a managament light on
wouldnt it?
Mike.
« Reply #4 on: 06 July 2012, 11:04:07 »
Hi TB
wouldnt it?
Mike.
No. There are no warning indicators on the levelling system. Get a code reader capable of reading the levelling system on it, that will save you guessing :)
