Author Topic: cat removale  (Read 3064 times)
pirate
  • westhumble surrey
    • steinmetz elit estate
cat removale
« on: 06 July 2012, 19:52:34 »
prob been asked before but im changing the exhaust on the steinmetz having one built from cats back but im thinking these pre face lifts can run without cats ?its a 2.5 at the moment but in the winter a 3.2 modified with a blower is going in so will have better manifolds etc and was thinking of having removable sections so i could put in for mot then take out .not worried re sensors on 3.2 as it will have completly different managment on it.
waspy
Re: cat removale
« Reply #1 on: 06 July 2012, 21:14:43 »
I think any car registered after 1993/4 has to have a cat unless it a diesel. Don't qoute me on the year :-\ It is around that time though :y
blackviper90210
  • Bromsgrove, West Midlands
    • 03 3.2 Elite Saloon
Re: cat removale
« Reply #2 on: 06 July 2012, 21:26:28 »
I think some have cut open the cats and gutted them, then resealed them. So when an inspection is carried out, it has the "cats" fitted  :-\
AKA - Mr Bracket
Manual Elite V6
  • Swansea
  • Mechanic and MOT tester at a Jaguar specialist.
    • 1992 Cavalier GSi
Re: cat removale
« Reply #3 on: 06 July 2012, 21:46:35 »
New MOT rules brought in from April state that if a cat is fitted as standard it has to be present at MOT time, even on a diesel.
1992 Cavalier GSi
2007 Astra Sri+ CDTi 150
tgm147
  • Wirral
    • '02 2.2 Omega CD
Re: cat removale
« Reply #4 on: 06 July 2012, 22:00:23 »
Not correct. That rule applies to all cars given a full emissions test. A diesel ISN'T given a full emissions test so it will still pass with no cat.
pirate
  • westhumble surrey
Re: cat removale
« Reply #5 on: 07 July 2012, 14:47:08 »
missed the point guys ,will fit removable cats for mot,its the running without will it thow up fault codes on the prefacelift v6 2.5 8)
tgm147
  • Wirral
    • '02 2.2 Omega CD
Re: cat removale
« Reply #6 on: 07 July 2012, 16:41:22 »
If there's a lambda sensor after the cats then yes it'll bring the emissions light on. Why not go for high flow sports cats instead? 100 or 200 cell ones should keep the lambdas happy enough.
adey2
  • nuneaton, warwickshire
  • if all else fails hit it with a hammer
    • 2000 3.0 elite estate lpg
Re: cat removale
« Reply #7 on: 07 July 2012, 16:42:00 »
mot tester was saying to me that due to car being on lpg it dont need a cat
v6 locking kit , code reader available, engine hoist and engine stand
also has 2.6 mv6 estate 2001, hilux surf 3.0, vectra 2.0 lpg 2000
pirate
  • westhumble surrey
Re: cat removale
« Reply #8 on: 07 July 2012, 19:32:26 »
sport cats bit pricey, re lambos they are well before cats in down pipes. :y
tgm147
  • Wirral
    • '02 2.2 Omega CD
Re: cat removale
« Reply #9 on: 07 July 2012, 21:09:01 »
If they are before the cats and there's nothing after I can't see why you'd get the EML light on if you remove the cats then.
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
    • Audi A6 Allroad BiTd
Re: cat removale
« Reply #10 on: 08 July 2012, 09:26:45 »
O2 sensors are before the cat's on a 2.5 / 3.0 so no problem.
Iirc, the v6's work better with a little back preasure so either leave along and spend your money on fitting a couple of 2.6 /3.2 manifolds  (which breath alot better) or if you have the money, a couple of sports cat's (with 2.6 /  3.2 manifolds)  :)
pirate
  • westhumble surrey
Re: cat removale
« Reply #11 on: 08 July 2012, 10:39:23 »
thanks thats the info i was after as ive had this prob before with back pressure i prob wont have the problem with a super charger pushing more through ,going for manifolds from germany on 3.2 tubler and flowed about £900 apair ouch
zirk
  • Epping Forest
    • 3.2 Manual Special Estate
Re: cat removale
« Reply #12 on: 08 July 2012, 12:15:07 »
Check that they have not been designed for a LHD.  ;)
Page created in 0.029 seconds with 16 queries.
