Author Topic: My Car won't start. No feed to the petrol pump. Help!  (Read 5146 times)
Greg2041
  • Frinton-on-Sea
The AA sub-contractor has given up.  Any ideas?
My car is a 3 litre V6.
Thank you
Greg
Re: My Car won't start. No feed to the petrol pump. Help!
« Reply #1 on: 08 July 2012, 15:08:21 »
What has lead to the diagnosis of fuel pump?
Have you read the codes?
« Reply #2 on: 08 July 2012, 15:33:51 »
Sounds like crank sensor mate. Duff sensor = no fuel delivery :)
« Reply #3 on: 08 July 2012, 15:48:20 »
Yep, probably crank sensor.Lookin maintenance guides for paperclip test and expect to find a code 19. Genuine sensor only. :y
Greg2041
  • Frinton-on-Sea
« Reply #4 on: 08 July 2012, 16:38:46 »
Thanks guys.  What would I do without you.  :y  Fault codes.  Would the AA know about them - or their sub-contractor?
If it is a crank sensor, dare I ask cost of part and labour.  Be gentle with me!
Greg
« Reply #5 on: 08 July 2012, 16:44:19 »
Greg
Get them with a paperclip http://www.omegaowners.com/forum/index.php?topic=90581.0
Greg2041
  • Frinton-on-Sea
« Reply #6 on: 08 July 2012, 16:49:43 »
I'll check when it stops pelting down with rain.  Are Crank sensors dear or difficult to fit? :-\
« Reply #7 on: 08 July 2012, 17:18:30 »
I believe the sensor is around £70. Takes 5 minutes (and one torx socket) to change.should be info in the guides. :y
  • Auckland
    • Mazda MPV
« Reply #8 on: 08 July 2012, 17:20:08 »
Have a read of the maintenance guide V6 Crank Sensor Replacement
Greg2041
  • Frinton-on-Sea
« Reply #9 on: 08 July 2012, 17:48:11 »
Thanks Peeps and for the link too.  I'll keep you informed.  ;)
Greg2041
  • Frinton-on-Sea
« Reply #10 on: 12 July 2012, 13:31:24 »
What a pain.  Yup, a faulty crankshaft sensor and now it starts but it takes ages and ages to do so and there is a loud click every now and again when starting.  Now it won't start again.
Any more ideas?  :'(
HELP!
« Reply #11 on: 12 July 2012, 14:17:30 »
You have found the fault. Crank sensor, it needs replacing. Geniune sensor only  :y
Dave DND
  • DND Services Ltd
    • Paignton, Devon
    • DND Services Ltd
« Reply #12 on: 12 July 2012, 16:00:07 »
Sorry, needed saying again
Geniune sensor only
 :-X
Radio & Decoding Technician
www.dndservices.co.uk
Greg2041
  • Frinton-on-Sea
« Reply #13 on: 12 July 2012, 19:16:23 »
Thank you peeps.  Anyone else want to say genuine sensor?  :o
Dave DND
  • DND Services Ltd
    • Paignton, Devon
    • DND Services Ltd
« Reply #14 on: 12 July 2012, 19:17:42 »
Only if you ended up fitting an el-cheapo pattern one   ::) :-X
