Author Topic: MoT oddities ................  (Read 1268 times)
I_want_an_Omega
« on: 10 July 2012, 17:57:19 »
Car passed MoT today with no advisorys  :y
Thing is that its the same testing station with the same tester as last year and then it had a couple of advisorys - "slight brake pipe corrosion" & "brake pipes greased". I've done nothing to change the situation and this time it didn't seem to be an issue. WHY?
Also, the emissions test results seemed to have improved slightly - again, using the same machine as last year. The only changes are that it now has fully synthetic oil in, and at the moment is running on super unleaded. Also, her usage has increased quite significantly and has done 9,000 miles between this and the last test, whereas it was only 1,200 miles last year.
Any ideas?
Re: MoT oddities ................
« Reply #1 on: 10 July 2012, 19:27:38 »
Because it's all about opinion ;) ;)
But the emissions may well improve slightly as it's actually been used ::)
