Pages: 1 2 [3]  All   Go Down
Author Topic: CD spec level  (Read 5554 times)
Jay w
  • Plymouth/Poole
  • omega gone
Re: CD spec level
« Reply #30 on: 02 April 2008, 23:29:44 »
am i right i thinking that FWD V6 engines will fit in the Omega so long as the sump is swapped over?
and all the other ancils as well?
« Last Edit: 02 April 2008, 23:29:58 by jay_w »
Re: CD spec level
« Reply #31 on: 03 April 2008, 08:33:36 »
Yes, needs most bits changing though including exhaust manifolds....
Jay w
  • Plymouth/Poole
  • omega gone
Re: CD spec level
« Reply #32 on: 03 April 2008, 08:48:55 »
that's not a problem....
My engine thagt i was supposed to be getting has fallen through, however i have access to a FWD V6 and was pretty sure it would go in so long as all the RWD stuff was transplanted.
so that would mean
Rocker covers
Manifolds
Plenium
Sump
Aside from that i would imagine all the other stuff would be the same....
Re: CD spec level
« Reply #33 on: 03 April 2008, 09:14:49 »
so that would mean
Rocker covers
Manifolds
Plenium
Sump
Cam covers (optional, you might prefer to keep the metal ones ass uming its a 2.6)
Exhaust manifolds
Cam belt cover (front wheel drive ones have a stability bracket that attaches through this)
Engine mounts
Aux mounts (aircon/PAS) and components
Sump pan (upper and lower)
Possibly the wiring loom.
Plenum
Flywheel/flex plate (dont forget the spigot bearing if auto/manaul)
Jay w
  • Plymouth/Poole
  • omega gone
Re: CD spec level
« Reply #34 on: 04 April 2008, 00:36:32 »
well i have sourced a 2.6V6 out of a 02 reg veccy, done 56,000 miles and they are sending me the service history with the engine to back it up.
That will arrive on tues, the engine will go on a stand, be cleaned, the old engine removed parts swapped over, the LPG injectors drilled into the inlet and then it will go back in......
Whilst the engine is out the cambelt & tensoners, waterpump, rocker cover gaskets and breathers will be replaced, genuine exhaust manifold gaskets used and the engine bay given a bit of a spruce up as well....
Martin_1962
Re: CD spec level
« Reply #35 on: 04 April 2008, 10:39:32 »
3.0 or 3.2 cams?
Jay w
  • Plymouth/Poole
  • omega gone
Re: CD spec level
« Reply #36 on: 04 April 2008, 11:25:42 »
3.0 or 3.2 cams?
well that's the query.......what fits and works?
nothing has ever really been tried and tested have they?
Martin_1962
Re: CD spec level
« Reply #37 on: 04 April 2008, 12:38:55 »
3.0 or 3.2 cams?
I have heard of a few things just to say when I do the head off I will be recamming as I will get a 2 at the front of the power, I want to take on the office manager at a drag strip (RWYB) and win.
He has a R32 2.0 turbo auto Skyline.
A few of us at work want a go but only 3 cars are at all that quick.
Jay w
  • Plymouth/Poole
  • omega gone
Re: CD spec level
« Reply #38 on: 13 April 2008, 14:24:13 »
Finally got some work done on it over the weekend......
Strapped a new battery to it, fired it up.......it rattled  ::)
Did a quick oil change...tried it again.......still rattled ::)
Dipstick has melted itself to the tube at some point  ::)
So got in it, started it up...........and just killed it....the noise was something else  :o
20 seconds at pretty much full throttle with zero oil pressure and then is slowed, stalled and refused to run any more  :-/ we killed it completely
just to be sure we did a amp draw test, it was chucking 720 amps to the starter and not turning at all
We have a 52,000 miles FWD V6 sat in the garage that is ready to go in, so next week we will be swapping components over and doing the refit.
We may have had a stroke of luck as well that may go some way to reducing the overall bill for the new engine, can say too much currently aside from it if does happen then there will be enough in the kitty for the LPG kit and still not break the 2k on the road cost  :y
Pages: 1 2 [3]  All   Go Up
