Pages: 1 [2] 3  All   Go Down
Author Topic: Omega Z22XE won't start after cam sensor swap  (Read 13995 times)
freecall666
  • looking over your shoulder
    • 2.0l sweat tank on wheels
Re: Omega Z22XE won't start after cam sensor swap
« Reply #15 on: 18 July 2012, 02:19:13 »
While waiting for the sensors to arrive I'll have a look at the fuel pump and relay's tomorrow. Is the fuel pump for the 2.2 Mig in the fuel tank?
yes in tank and not easy to get out have to push the 3 clips back t same time and pull out, can somtime doit with a wiggle but fiddley with the space there is.
Solar charger fitted.
If not Broke dont fix it..
Nforce
  • Ireland
    • Omega 2.2lt 16v
« Reply #16 on: 18 July 2012, 10:41:51 »
Thanks again freecall666. :y
I checked out both this morning and they are fine. Got a replacement cam sensor delivered today too,swapped it in and same issue...car will turn over on the key but won't fire. My last hope is if a replacement crank sensor will do the trick, though I believe the 2.2's will actually run on a faulty one?
markrnorton
  • Essex
    • 2.2 & 2.5 Ginetta build
« Reply #17 on: 18 July 2012, 12:40:02 »
this sounds like the problem i just had !
Nforce
  • Ireland
    • Omega 2.2lt 16v
« Reply #18 on: 18 July 2012, 12:41:12 »
Did you find out what the problem was with your's?
Edit: I just spotted the issue with your car. Mine had an ECU/Immobiliser/Transponder changed a few months ago so I don't think that's the issue...also no fault codes showing on my car.
« Last Edit: 18 July 2012, 12:45:16 by Nforce »
markrnorton
  • Essex
« Reply #19 on: 18 July 2012, 14:17:42 »
Yes
the point i was making is that i have changed the cam sensor, crank sensor, fuel pump.. just sounded similar !
crank sensor is a pig of a job
Nforce
  • Ireland
    • Omega 2.2lt 16v
« Reply #20 on: 18 July 2012, 14:32:50 »
Cheers Mark. I'm not looking forward to doing the crank sensor...but needs must! ;D
I did notice that there's a loose connector block with a single wire (black/blue) tucked down by the ECU. Anyone know what this is for?
markrnorton
  • Essex
« Reply #21 on: 18 July 2012, 14:40:20 »
I noticed that as well
I didnt like to ask !  ;)
Nforce
  • Ireland
    • Omega 2.2lt 16v
« Reply #22 on: 20 July 2012, 15:55:37 »
Crank sensor changed out today (and yes...it is a pig of a job), but the non starting issue remains :-\
Help! :-[
Nforce
  • Ireland
    • Omega 2.2lt 16v
« Reply #23 on: 21 July 2012, 11:54:55 »
No spark at the plugs so I reckon it's the DIS pack that's failed...unlikely that all 4 plugs would fail at once.
Nforce
  • Ireland
    • Omega 2.2lt 16v
« Reply #24 on: 25 July 2012, 12:31:21 »
Brand new DIS pack fitted,still no spark. With ignition key switched to position 2 I'm getting power at #1 and #2 on the DIS electrical connector ...is this correct?
markrnorton
  • Essex
« Reply #25 on: 25 July 2012, 12:32:57 »
It sounds like you are getting as frustrated as i was !
Nforce
  • Ireland
    • Omega 2.2lt 16v
« Reply #26 on: 25 July 2012, 12:37:07 »
I don't want to scrap the car...but it's looking like I'm out of options at this stage.:(
Steve B
  • Leicestershire
    • '52' MV6 3.2 Saloon
« Reply #27 on: 25 July 2012, 12:43:02 »
been following this..how do you know you dont have any sparks at plugs
Nforce
  • Ireland
    • Omega 2.2lt 16v
« Reply #28 on: 25 July 2012, 12:45:42 »
Hi,
I removed the DIS pack and inserted the plugs directly into it. Then tested for a spark on each plug with an earthed piece of metal (old jump leads). The plugs are wet with petrol too after removing them from the head.
Steve B
  • Leicestershire
« Reply #29 on: 25 July 2012, 12:47:46 »
Hi,
I removed the DIS pack and inserted the plugs directly into it. Then tested for a spark on each plug with an earthed piece of metal.
ok it was that part i was going to mention but you did earth the plug :y
Pages: 1 [2] 3  All   Go Up
