Pages: 1 2 [3]  All   Go Down
Author Topic: Omega Z22XE won't start after cam sensor swap  (Read 13997 times)
Nforce
  • Ireland
    • Omega 2.2lt 16v
Re: Omega Z22XE won't start after cam sensor swap
« Reply #30 on: 25 July 2012, 12:52:41 »
Sorry just re-read that....yes the plugs were tested with an earthed cable.
However,the fact that the plugs are wet with fuel should mean that there's no spark?
« Last Edit: 25 July 2012, 12:56:18 by Nforce »
Steve B
  • Leicestershire
    • '52' MV6 3.2 Saloon
« Reply #31 on: 25 July 2012, 12:57:58 »
OOps..No, I didn't :-[.
i would go and earth them up and crank over just to be sure there is no spark
Nforce
  • Ireland
    • Omega 2.2lt 16v
« Reply #32 on: 25 July 2012, 13:01:17 »
Thanks for the help bigtimecube :y
Steve B
  • Leicestershire
« Reply #33 on: 25 July 2012, 14:08:28 »
This problem seems to have came about after you changed the cam sensor.
its a shot in the dark but when you done cam sensor.do you remember pulling that wire loom/trunking around on the cam cover
are you sure something has not came unplugged a little but not enough to be easily noticed :y
Nforce
  • Ireland
    • Omega 2.2lt 16v
« Reply #34 on: 25 July 2012, 17:45:27 »
All connectors are fine from what I can gather. It's a mystery,alright. :-\
Nforce
  • Ireland
    • Omega 2.2lt 16v
« Reply #35 on: 28 July 2012, 16:32:23 »
Bump
Double and triple checked the wiring connectors,still no joy. There's definitely no spark at the plugs. New DIS pack fitted and the DIS electrical connector appears to be receiving power on  #1 and #2 with the ignition switched to position 2. Any help gratefully accepted :-[
Raeturbo
  • South Wales
    • TouregR5Mitsi Evo2. XJ8
« Reply #36 on: 09 January 2017, 20:48:40 »
Did this ever get fixed?
Laying a rubber road.
Pages: 1 2 [3]  All   Go Up
