Author Topic: central locking help  (Read 1892 times)
p100drift
« on: 16 July 2012, 10:10:34 »
i have a 94 omega estate central locking has died only bit of life it a relay in the control unit when i work the key fob. the rear doors are stuck unlocked (cant lock them) front doors are working off the key now after working the key forward and back for a bit
fuse 20 has power and not blown
is there meant to be a positive supply to the front door motors???????
anyone have a diagram or pinouts for the control unit and or motors
any help would be grate. really want to lock my car :)
freecall666
  • looking over your shoulder
    • 2.0l sweat tank on wheels
Re: central locking help
« Reply #1 on: 16 July 2012, 17:01:06 »
there is a long black relay, have not looked for it on mine, but it controls the power to the motors to unlock and lock. it may be in the fuse box or behind the glove box. ive herd it click on mine when locking the doors from inside with the key.
Solar charger fitted.
If not Broke dont fix it..
freecall666
« Reply #2 on: 16 July 2012, 17:28:13 »
this may help you. http://opeloem.com/vauxhall/omega_1994_2003/accessories/body_interior_fittings/central_locking_system.html
p100drift
« Reply #3 on: 23 July 2012, 14:19:56 »
this is what i was looking for. i would have thought someone would have posted this up took a while to find  :'(
Admin edit to remove copyrighted material
turned out to be a bad body earth that mounts just above the central locking unit (bottom of the a pillar beside drivers feet)
to freecall the click from behind the glove box is the alarm control unit it turns out
« Last Edit: 23 July 2012, 20:09:04 by Jimbob »
