Author Topic: 2 stroke fuel to oil mix etc?  (Read 4668 times)
the alarming man
  • medway kent
    • disco V8
Re: 2 stroke fuel to oil mix etc?
« Reply #15 on: 18 July 2012, 12:51:27 »
i remeber being taught too ride like that...been a long time since i have been near a bike though... :y
Varche
  • middle of Andalucia
    • Golf Estate
« Reply #16 on: 18 July 2012, 14:37:32 »
I have always thought it bordering on the miraculous that 2 stroke engines actually run without siezing. Revving their nuts of,with just a dribble of oil mixed with the petrol to lubricate the crank bearings,bore,small end etc. It shouldnt really work but it does.
The quality of the oil has improved greatly though since the advent of synthetic oils.
I (along with many others of my age group) still habitually tend to ride a motorbike with the fingers of my left hand hung over the clutch lever,as it was often necessary to pull the clutch in sharpish on 70,s 2 strokes when you felt the engine start to tighten up. ;D
[/highlight]
As a young teenager I had loads of bikes for tracking. One was a BSA Bantam. The throttle cable snapped so I slipped it over the frame beind the tank and attached it to the rear brake pedal(having disconn'd the rear brake). The clutch cable always jumped out of the socket unless you permanently rode holding the slack. Our neighbour who was old enough to go on public roads and had a 650 bike asked if he could borrow my bike. I explained the workings and pointed out the front brake was very good! Be careful.
What happened was best explained by the lady riding the horse. A speeding m'bike appeared, saw me and went to slow down. But accelerated, went to use the clutch and it had dropped out of the socket so applied the only thing left the front brake which pitched him off the bike. ;D ;D
« Reply #17 on: 18 July 2012, 14:40:30 »
Like it. :y  ;D ;D
« Reply #18 on: 18 July 2012, 15:52:42 »
i used an old can of petrol for chain saw mix been in the can can for over 2years. needed to burn some hedge cutting, so thought to use it up and put a bit on to get it started. well not doing that again, lit the match put it on the petrol BOOM blow me side ways, every one in the hole street open'd there windows  to see what was going on. and the fire never even started just a big Boom, well not doing that again...
That petrol still works, then. ;D
Eyebrows intact?
