Author Topic: Veccy C 3.2. Oil filter housing problem ...........  (Read 2530 times)
I_want_an_Omega
« on: 20 July 2012, 09:03:35 »
Hi,
A mate has an '05 Veccy C with the 3.2 engine. Has a problem with the oil filter housing which has sprung a leak a few hundred miles after service, coating much of his engine bay and underneath the car with oil :'(.
Possibly a cracked housing?
Suggestion is that the filter housing/seal is a poor design and that they fail sometimes, is this true?. Was perfect for 200 miles after the service and then the leak happened. I thought the housing had to be torqued up as on the Omega, is this true?
Thanks - Rob
Tonka.
  • Lincoln, Lincolnshire
    • 2000 2.5 CDX
Re: Veccy C 3.2. Oil filter housing problem ...........
« Reply #1 on: 20 July 2012, 09:10:04 »
Apparently, the oil filter cap is tightened to 25Nm Rob.
Cheers Sean
The happiest people don't have the best of everything,
they just make the best of everything they have.
I_want_an_Omega
« Reply #2 on: 20 July 2012, 10:09:50 »
Cheers Sean
Thought so - but are we 100% sure that this applies to the Veccy/Signum engine as well? I can't see why it wouldn't TBH, and suspect that it's been over tightened and cracked.
twiglet
  • Norwich, Norfolk
« Reply #3 on: 20 July 2012, 10:44:48 »
Cheers Sean
It's only 15Nm on the Omega.  :y
Tonka.
    • 2000 2.5 CDX
« Reply #4 on: 20 July 2012, 10:54:09 »
I pulled that figure off an oil change guide for the Vectra 3.2 on the web so may be innacurate  ::)
« Reply #5 on: 20 July 2012, 12:32:40 »
I'd imagine its the same part, which would then have 15Nm stamped on it. Which is the big give-away ;)
Its possibly that its come loose at the housing to block end, not uncommon if the previous fitter had overtightened.
« Reply #6 on: 20 July 2012, 12:45:56 »
The later 1800 Vectra has a plastic filter cap, I only ever nip that up :-\ is the cap metal as per the Omegas?
I_want_an_Omega
« Reply #7 on: 21 July 2012, 21:05:51 »
Andy C has confirmed that it's the same part number as on the Omega.
Thanks guys, car goes in for rectification next week.
