Author Topic: bugger  (Read 4348 times)
sticka_v8_init
  • Reading
    • 2.5 V6 Tourer
Re: bugger
« Reply #15 on: 21 July 2012, 10:33:49 »
Sounds like a blow back and ignition in the airbox/induction area. You may not have a complete intake system left!
Those are my principles, if you don't like them I have others.
Re: bugger
« Reply #16 on: 21 July 2012, 11:55:21 »
First prize to Mr Gixer.
I'm guessing the bang was it hitting something.
I knew immediately what it was, just not where - and I heard the feed depressurise. It sounded underneath, and it happened as I drove (slowly!) through a pothole, although it wasn't deep. But initial reaction was caught the gas pipe.
The safety systems worked as expected, and shut the tank valve.
Just hope I have all the required bits still....
Re: bugger
« Reply #17 on: 21 July 2012, 12:09:15 »
Poly feed to vap?
Position of the pipe under the car means it won't ground on a flat surface. There would have to be high point to protrude into the fuel line run...?
Or the jolt was enough to make a loose join fail under pressure..?
Re: bugger
« Reply #18 on: 21 July 2012, 12:41:57 »
Yup, the fitting has come out of the liquid filter. Hope the olive is still inside.
Wasn't much of a jolt, that bit of road is like going up a rough track, so walking pace maximum.
Re: bugger
« Reply #19 on: 21 July 2012, 13:14:19 »
If you're short of anything let me know and I'll rummage in my LPG junk box.
Re: bugger
« Reply #20 on: 21 July 2012, 13:25:26 »
Olive will be in there, unless the brass nut has come undone?
Or has the poly blown off the bayonet fitting? (edit, ignore the last line)
« Last Edit: 21 July 2012, 13:28:16 by chrisgixer »
Re: bugger
« Reply #21 on: 21 July 2012, 21:07:29 »
Fixed. Thanks for all your help :)
No idea why it came adrift though  :-\
Re: bugger
« Reply #22 on: 21 July 2012, 21:13:47 »
Probably all that retard induced driving you've been doing this week ::)
