Author Topic: Wheel balancing oddity  (Read 5859 times)
freecall666
  • looking over your shoulder
    • 2.0l sweat tank on wheels
Re: Wheel balancing oddity
« Reply #15 on: 23 July 2012, 22:08:33 »
at c browns full geometry, they said there was only a bit out 20min job in end after had to undo the adjusters my self but was only £40, taking it back in to check next week as fin the wish bones and a few other stuff so will need re checking.
it was a lazer setup then tuck back aweek later for the last check.
Post up the before and after settings, so we can see how good they are for the benefit of local members :y
when i get new one done. old one thrown away.
Solar charger fitted.
If not Broke dont fix it..
freecall666
« Reply #16 on: 24 July 2012, 01:52:09 »
just found this garage that does 4 wheel traking/alightment for £25 in not's http://www.nottinghammotcentre.co.uk/ if any good to any one.
« Reply #17 on: 24 July 2012, 09:17:39 »
I hear this a lot. But I also hear it costs about £100 a pop...... :o :o :o :o
Is this cost effective on a car as worthless and elderly as an Omega?
It's worth shopping around... My local tyre depot charge for each adjustment they make.. so once you have the car basically setup well, it's better to go there for a check. Last time only the toe needed tweaking... £15. :y
I also have them well trained on the Omega now. ;)
Webby the Bear
  • Northampton
    • 2000 (W Reg.) 2.5 V6 CD
« Reply #18 on: 24 July 2012, 12:32:12 »
save startin' a new thread...
what's the recommended min pad and disc thickness for the rear? i have a feeling the haynes stats are wrong  :-X going to measure them later on as i know my fronts are ok :)
also any recommendations for where to buy pads and discs that aren't from vaux? they want £100 for 2 front discs and 4 pads so i'm thinking if the rear needs doing they'll be just as expensive.
RIP Paul Lovejoy
Webby the Bear
  • Northampton
« Reply #19 on: 24 July 2012, 12:32:44 »
and ps thanks for the info on the balancing/aligning chaps  :y
RIP Paul Lovejoy
Webby the Bear
  • Northampton
« Reply #20 on: 24 July 2012, 12:33:22 »
...oh and i have non vented rear discs  :y
RIP Paul Lovejoy
freecall666
« Reply #21 on: 24 July 2012, 15:23:58 »
printer was not working but only needed front doing pass side was 0.9 drivers side 0.6. done on a computer. says he will keep it for me.
freecall666
« Reply #22 on: 24 July 2012, 15:26:03 »
back ones not vented are half the price.
Webby the Bear
  • Northampton
« Reply #23 on: 24 July 2012, 22:03:15 »
Thanks guys. Any ideas on the minimum thickness for the rear pads and discs? I've looked on the oof servicing intervals but nowt on there. Cheers all :-)
RIP Paul Lovejoy
Webby the Bear
  • Northampton
« Reply #24 on: 24 July 2012, 22:05:06 »
god I'm thick. Sorry free call. Just re read your post. Thanks for the info and ignore this ageing old fool.
RIP Paul Lovejoy
« Reply #25 on: 24 July 2012, 22:05:13 »
No. 4 wheel alignment is not much use usually on Omegas.
« Reply #26 on: 24 July 2012, 23:56:27 »
Most tyre places will offer a 4 wheel alignment for £25 - a few will even charge as much as £40  ::) ::) ;)
