Author Topic: Pictures question  (Read 6396 times)
YZ250
  • Oxford/Bucks border
    • Black 3.2 Elite Estate
Re: Pictures question
« Reply #15 on: 26 July 2012, 09:48:47 »
Sorry cam, forgot you were on iPad. Above works for iPhone.  :-[
For iPad Photobucket App:
Tap Photobucket App on ipad----->Photobucket front page should come up------->probably default to 'Find Stuff (bottom left)---->tap lower middle button (My Albums)------>tap arrow pointing up in upper right hand corner -------->choose upload source (photo library)------>tap camera roll------>select photo-------->when you tap this a box on the left says 'processing' -------->in 'My Album' tap photo ------>tap chain icon (upper right menu)------->tap IMG code------> it should say 'Copied'------>go to OOF and open new topic or open reply, depending on what you want to do----->tap in reply box/new topic box or whatever until 'Select/Select All/Paste' option appears on screen----->tap 'Paste' option----->go to 'Preview' and your photo should be there on screen. Type message as normal and jobs a goodun as they say.  :y
Hope that makes sense.  :y
Regards
Alan
Tried again, ok, so I've copied the image to clipboard in photobucket...opened a new topic in th OOF gallery......you then say to tap the new topic until select/select/all/paste comes up? It doesn't.
As its a new topic there's no reply button yet, and there's no select/paste option that I can see? Have I followed your instructions correctly??
Really sorry to be a pain, bugging the life outa me that I can't get pics up, and that the world and his wife seem to be able to without a problem.... Leaving me feeling very inadequate that I can't. Story of my life!!   ;D ;D ;D
Right, let's take it a step at a time.  :y I'm determined as well now.  ;D
Have you got to the stage where you can tap the IMG link in Photobucket app and it says 'copied'?
If you have, you can either practice in 'Test Area' or open 'New Topic' in Gallery section if that's where you want to post the image.
As far as the forum part goes, open new topic, write in the new topic box 'My New Car' or whatever, go to the large reply box below (where you normally type your replies), tap the screen in that box and I would expect to see select/select all/paste. If not, we'll try to find out at what stage it's going wrong.  :y
Regards
Alan
YZ250
« Reply #16 on: 26 July 2012, 09:55:56 »
If you at the 'copied to clipboard' stage you must be nearly there.  :y
I assume you saw this on your screen? Sorry the photo is big. Below is the 'copy paste' bit. If you have tapped on the IMG code (where it says copied to clipboard) you have done the Photobucket app part successfully.  :y
You are so close if you have got this far.
« Last Edit: 26 July 2012, 10:05:41 by YZ250 »
« Reply #17 on: 26 July 2012, 10:18:26 »
You should have that made into a How To, YZ250!
cam2502
  • dumfries,scotland
    • 08 BMW 520d & 03 Saab 95
« Reply #18 on: 26 July 2012, 10:27:25 »
Ok, following your instructions... I tapped the large box where I would normally write... I have now got the copy/ paste thing up.... But no image of the car
YZ250
« Reply #19 on: 26 July 2012, 10:34:13 »
Does it not appear when you tap preview?
I did consider that actually.  ;D ;D I just did the old favourite of mine, which is trying to type on a screen dump.  ;D ;D
cam2502
  • dumfries,scotland
« Reply #20 on: 26 July 2012, 10:34:30 »
On photobucket.. I have tapped the pics I have and copied to clipboard, tapped the img option in the box that appears after I tap the paper clip logo at top of the page....
Now back to OOF, I have written my heading (my car) and tapped the box where I would write a post..... I now get the copy/ paste select options, but there is no image of the car in the box....
cam2502
  • dumfries,scotland
« Reply #21 on: 26 July 2012, 10:38:13 »
Think I've jumped the gun a bit Alan. Sorry. Realised the photo of your car was in the photo bucket explanation. Yes I've done that with mine, so I'm back to OOF now, and as said above I have the copy/ select option on he big box... Over to you... :y
« Reply #22 on: 26 July 2012, 10:44:10 »
You won't get a picture until you submit or preview, but you should see the [ IMG ]somecodestuffhere[ /IMG ] tags be inserted into your post..
cam2502
  • dumfries,scotland
« Reply #23 on: 26 July 2012, 10:47:01 »
Need to know what I do now that I've pressed on this box and the copy/ select option has come up though
YZ250
« Reply #24 on: 26 July 2012, 10:53:20 »
Are you seeing copy/paste or select/select all/paste?
So you have done the part shown in reply #16 that comes up 'copied to clipboard' when you tap the IMG code in Photobucket app?
Second part is the lower part of that reply. As said above, you will not see a photo until you hit preview. It should appear in the preview box above.
Feel free to call me, pm on way.  :y
Regards
Alan
Edit:
Would it help if I took screen shots of the whole process.
« Last Edit: 26 July 2012, 11:03:13 by YZ250 »
cam2502
  • dumfries,scotland
« Reply #25 on: 26 July 2012, 10:59:50 »
Finally managed it Alan! Pics now on the gallery. Many many thanks, this was cracking me up. Thanks again mate,  :yil post more pics when I take them later. :y
YZ250
« Reply #26 on: 26 July 2012, 11:16:10 »
Brilliant  :y
I was prepared to carry on until we got a result.  :y
Regards
Alan
