Author Topic: Couple of things............  (Read 4514 times)
Joiner
  • Leighton Buzzard, Bedfordshire
    • Omega 2.6 V6
« on: 24 July 2012, 18:39:13 »
Hi all.
Firstly, does anyone know if its possible to get a replacement washer for an coolant expansion tank cap? My flat rubber washer has split and doesn't provide a particularly good seal unless you really welly it up tight. I know I could go to a MD and get the whole thing but there is nowt wrong with the tank and cap so see no point on spending 40 to 50 quid on a complete new tank.
Secondly, I have just fitted a new oil cooler, thermostat, stat housing and transfer pipe. Everything is fine as it should be, however since putting it all back together my service light has come on. I think its the service light? Its the one with a car and a spanner through it vertically, amber in colour.
Anyone have any ideas why this should happen?
Like I said, all is as it should be or at least seems to be................... :-X :-X :-X :-X
Cheers :y
martin42
Re: Couple of things............
« Reply #1 on: 24 July 2012, 19:26:27 »
Motorfactors,for cap,pedal trick to bring up fault codes
« Reply #2 on: 24 July 2012, 19:31:12 »
Hi all.
Cheers :y
Left something unplugged. Check the rear muti-ram connector
Joiner
    • Omega 2.6 V6
« Reply #3 on: 24 July 2012, 19:54:18 »
Hi all.
Cheers :y
I'm sorry fella but you've lost me there ??? ??? ???
martin42
« Reply #4 on: 24 July 2012, 20:03:33 »
Rear of plenum there is a black pump that operates the ram,might not be plugged in :y
« Reply #5 on: 24 July 2012, 20:09:20 »
solenoid
« Reply #6 on: 24 July 2012, 20:15:04 »
Circled yellow
Joiner
    • Omega 2.6 V6
« Reply #7 on: 24 July 2012, 20:20:15 »
Circled yellow
Thanks for that, i'll have to take a look tomorrow.
Out of curiosity, I know a bloke who has the diagnostics unit that plugs in under the steering column. Would that give a deffinate answer as to why this light has come on? He charges a modest £15.00 to runa check on the system but if its inconclusive then there is no point.
Thanks everyone btw for the input :y :y
« Reply #8 on: 24 July 2012, 20:23:36 »
Save yourself £15 and do the "pedal test" http://www.omegaowners.com/forum/index.php?topic=90581.0
amba
  • Medway towns
    • German V6
« Reply #9 on: 24 July 2012, 20:24:31 »
It would almost be quicker to get your hand around the back of the plenum to check the multiram connecter than get a diagnostic reader plugged in  :y
« Reply #10 on: 24 July 2012, 20:26:55 »
Pedal test is cheaper.
However, if ever you get to Brackley, I have the proper diags kit for it, or with a bit of planning, get to Bletchley one weekday lunchtime ;)
Joiner
    • Omega 2.6 V6
« Reply #11 on: 24 July 2012, 21:51:36 »
Again, thanks everyone! :)
Like the pedal trick, deffo cheaper than getting my mate involved ;D
Anyway, is there a comprehensive list on OOF for the code meanings?
I have performed the test now and got three fault codes.
10 3 10 10
10 3 10 1
10 3 3 10
Looks like I still have things to sort out ::)
« Reply #12 on: 24 July 2012, 21:54:48 »
Sure that 3rd one is right?
First 2 are misfire related.
jibberwobble
  • swindon
    • 3.0 MV6 Estate 2000 W
« Reply #13 on: 25 July 2012, 04:27:23 »
I'm breaking my 2.5 omega. You can have the expansion bottle cap for the price of postage if it's any good to you? (sorry mods, I know I'm not supposed to be selling stuff with a low post count but I'm actually giving it away)
Joiner
    • Omega 2.6 V6
« Reply #14 on: 25 July 2012, 23:12:24 »
Deffinately, checked and rechecked and all three readings are 100% correct. :y
Cheers buddy, very generous of you but I have since bought one from Ebay for a couple of quid. Thanks again though mate. :)
