Author Topic: Couple of things............  (Read 4509 times)
Re: Couple of things............
« Reply #15 on: 26 July 2012, 00:09:12 »
Again, thanks everyone! :)
Like the pedal trick, deffo cheaper than getting my mate involved ;D
Anyway, is there a comprehensive list on OOF for the code meanings?
I have performed the test now and got three fault codes.
10 3 10 10
10 3 10 1
10 3 3 10
Looks like I still have things to sort out ::)
Knock sensor cable trapped or chaffed exposing co-ax :-\
Joiner
  • Leighton Buzzard, Bedfordshire
    • Omega 2.6 V6
« Reply #16 on: 26 July 2012, 07:32:46 »
10 3 10 10
10 3 10 1
10 3 3 10
How bad is that Rob and how would I go sorting that out? Is/would it be something I could have done when doing the oil cooler change perhaps?
Steve B
  • Leicestershire
    • '52' MV6 3.2 Saloon
« Reply #17 on: 26 July 2012, 07:51:02 »
Joiner
    • Omega 2.6 V6
« Reply #18 on: 26 July 2012, 21:34:36 »
Could anyone point me in the direction of where the knock sensor is? I wouldnt know where to start looking TBH.
Also, am I likely to damage anything continuing to use the vehicle whilst this is going on?
« Reply #19 on: 26 July 2012, 23:34:49 »
0330, knock sensor 2 passenger side. Just below #4 pot on block, squareish connector. There should be a connector on a flying lead around the area where the main loom goes to the ECU box for the knock sensor.
Knock sensor actually plugs in on plastic cable tray running over passenger side bank of cylinders and drops down by dipstick tube. Find the connector then follow the screened cable to it.
« Last Edit: 26 July 2012, 23:37:57 by RobG »
