Author Topic: Mrs Opti's Corsa fails it's M.O.T  (Read 2498 times)
« on: 26 July 2012, 19:59:40 »
..........her 53 plate 1.2 SXI failed on split CV joint gaiters..........which according to the fail slip " no longer prevent the ingress of dirt"
It also had an advisory for rusty front brake discs. :'(
They fitted new gaiters while I waited, at a cost of £35 including V.A.T. This meant I received a pass slip and an M.O.T. that runs to 17th August 2013. A great feeling. :y
The front disc ARE very rusty, so I also purchased a pair of genuine Vx discs and pads which I'll fit myself at a later date. These cost £68 including V.A.T.
Yeah...yeah.....I know, with trade card (TC) they'd cost about £30. :-[......Pity my local Vauxhall dealer won't accept it.
Re: Mrs Opti's Corsa fails it's M.O.T
« Reply #1 on: 26 July 2012, 20:25:59 »
Interesting , someone i know will need both gaiters replacing on a corsa ...very good price fitted  :y Will see how much they will charge around this area  ::)
« Reply #2 on: 26 July 2012, 20:30:39 »
I also thought the price was reasonable, EMD. It took the guy thirty minutes.......I was watching very closely. :y
« Reply #3 on: 26 July 2012, 20:42:41 »
Rusty discs you say , so do you mean they were rusty on the outer edge ...  :)
« Reply #4 on: 26 July 2012, 20:49:30 »
Mainly rusty on the back from what I could see.
Funny thing is this, "rusty discs" showed up as an advisory on the 2009 M.O.T.......vanished in 2010 and 2011 only to return in 2012.The discs have not been changed during the interim period. Spooky.....There are dark forces at large in the world of the M.O.T. tester.
« Reply #5 on: 26 July 2012, 20:52:26 »
Oh i see , i seem to recall AndyB's pics of rusty discs on the backs ... very crusty  ;)
« Reply #6 on: 26 July 2012, 20:55:23 »
Friendly tester explained that braking performance was fine.......so merely an advisory, rather than a fail. :y
« Reply #7 on: 26 July 2012, 20:58:38 »
Mrs opti will be pleased to know your full mechanical attention will be showered all over her corsa  :y
« Reply #8 on: 26 July 2012, 21:05:32 »
I'm expecting extra rations...... ;)
« Reply #9 on: 26 July 2012, 21:31:33 »
Oh dear  ::), good luck with that then ..corsa shouldt take more than a couple of weeks to fix  ;D :y Sturdy old things the corsa and can take some bashing esp the 3 pots  :-X
