Author Topic: Starting Problems  (Read 1204 times)
Gerard
Starting Problems
« on: 27 July 2012, 18:49:39 »
I had used my car, an Omega 2.6 V6 and it was starting first time and was showing no signs of any problems. I went back about 5 minutes later, started, all lights came on, but the engine did not turn. I have tried a few times since, but nothing. I am not a mechanic, is it the battery or something else?
martin42
Re: Starting Problems
« Reply #1 on: 27 July 2012, 18:56:00 »
if its an auto have you made sure it is in p or n
do ignition lights dim when trying to start it
Gerard
« Reply #2 on: 27 July 2012, 18:59:00 »
It is a manual, and no the remaining lights on the dashboard seem to remain the same.
martin42
« Reply #3 on: 27 July 2012, 19:01:05 »
several things,ignition switch faulty,starter packed up(unlikely) or a loose connection so check everything is tight on battery and alternator
