Author Topic: washers not working  (Read 5741 times)
Re: washers not working
« Reply #15 on: 30 July 2012, 18:53:56 »
check the group of earth wires just under the battery to the left.
Sorry, didn't see this before. Not really relevent in this case, as its not where the system is grounded :)
Arpy
  • Preston
  • 02 2.2 cdx estate auto
« Reply #16 on: 30 July 2012, 19:04:36 »
thanks I thought i had to remove steering wheel before doing anything else (haynes manual)
I will have a bash tommorow at investigating .
« Reply #17 on: 30 July 2012, 19:05:28 »
Wiring diagram is in same Haynes manual :y
« Reply #18 on: 30 July 2012, 19:07:58 »
Steering wheel at 90 degrees anticlockwise, reveals a screw underneath a cap.
Steering wheel at 90 degrees clockwise, reveals similar screw other side
Top cowling lifts off
Unscrew rake adjustment
3 screws under lower cowling
Untangle from rubber around ignition
lower cowling drops off
To quote Haynes, refit is reverse method.
« Reply #19 on: 30 July 2012, 19:08:19 »
as I said (#8  ;)) just a few screws to remove the cowling - not even sure you need to remove the handle from the column tilt lever.  :y :y
« Reply #20 on: 30 July 2012, 19:12:49 »
as I said (#8  ;)) just a few screws to remove the cowling - not even sure you need to remove the handle from the column tilt lever:y :y
Doable, but really fiddly lifting over ignition switch. Far quicker to unscrew it, for the 3s it takes...
« Reply #21 on: 30 July 2012, 19:21:27 »
As long as it will come off. I never managed to remove my Senator's  ::)  :y ....... but we're digressing  ::) ::)
I am a Daisy
  • Stonehoose
« Reply #22 on: 30 July 2012, 19:29:28 »
I had a problem with my headlights, they were working fine before I did some work, after that they didnt work on one side. Did as many checks as I could including stalks, turns out it was the fuse holder in the fuse box wasnt getting a good connection, maybe this is where your problem lies?
« Reply #23 on: 30 July 2012, 19:32:48 »
Fuse proved OK
I am a Daisy
  • Stonehoose
« Reply #24 on: 30 July 2012, 19:42:42 »
I mean the actual part the fuse blades slot into, my fuses were all good, it was the lower of the two connectors for that fuse, in the fuse box
« Reply #25 on: 30 July 2012, 20:51:14 »
All proved OK
