Pages: 1 [2] 3  All   Go Down
Author Topic: Unknown wires  (Read 8625 times)
adey2
  • nuneaton, warwickshire
  • if all else fails hit it with a hammer
    • 2000 3.0 elite estate lpg
Re: Unknown wires
« Reply #15 on: 05 August 2012, 16:22:34 »
prob there is tb is lots of these fast fit towbar companies havent a clue, mines just as bad but stereo on louder has become a common override or take kids sweets off them so they scream
v6 locking kit , code reader available, engine hoist and engine stand
also has 2.6 mv6 estate 2001, hilux surf 3.0, vectra 2.0 lpg 2000
Re: Unknown wires
« Reply #16 on: 05 August 2012, 16:24:42 »
Fit an inline switch on the Red wire from reversing lights to the Park Pilot ECU.
I bet the idiots used scotchlocks as well  >:(
adey2
Re: Unknown wires
« Reply #17 on: 05 August 2012, 16:28:00 »
be just my luck to forget to turn back on and missis will give me a insurance claim as she puts towbar through someones radiator whilst reversing in asda
Re: Unknown wires
« Reply #18 on: 05 August 2012, 16:29:05 »
You could try to fix the wiring that the cowboys did, but from memory, it needs a different socket.
m.ian
Re: Unknown wires
« Reply #19 on: 05 August 2012, 16:31:03 »
Thanks for the suggestion but the tow bar was fitted when i brought the car.
Is the correct/factory electrics available?
Re: Unknown wires
« Reply #20 on: 05 August 2012, 16:33:06 »
Just to throw a spanner in the works... Surely if those wires pictured aren't connected to anything the OP doesn't have Park Pilot fitted and they're aftermarket too :-\ ???
adey2
Re: Unknown wires
« Reply #21 on: 05 August 2012, 16:33:34 »
i will do when i get round to that end of car, got to remove towbar at some point to fit washers to the fixings as idiots used a hole cutter to drop inserts through to chassis so the boot floortakes none of the load and towbar twists, could be a interesting fix
Re: Unknown wires
« Reply #22 on: 05 August 2012, 16:40:04 »
They should drill a hole large enough for the inserts only and there should be a spreader plate over the top ;)
adey2
Re: Unknown wires
« Reply #23 on: 05 August 2012, 16:42:30 »
yeah but the inserts should be sandwiched between the floor and chassis rails, mine can be dropped in the top hole and fall out the bottom
Re: Unknown wires
« Reply #24 on: 05 August 2012, 16:58:18 »
Ahh... I understand what you mean now :-[ ::)
Re: Unknown wires
« Reply #25 on: 05 August 2012, 17:10:52 »
Why do you think they are not connected  :-\
Re: Unknown wires
« Reply #26 on: 05 August 2012, 23:18:41 »
That's how I read the first post ;)
Hi All,
Found some un-attached wires in the NSR space behind the light cluster
How do I post pictures of them as want to know what they are for?
Ian
Could be wrong though ???
m.ian
Re: Unknown wires
« Reply #27 on: 06 August 2012, 20:17:00 »
Update,
Spoke to local Vauxhall dealer and electrics available to disable fog lights and parking sensors :)
ONLY £320.00 + Vat as comes as complete set with tow bar :(
Not going down this route!
Re: Unknown wires
« Reply #28 on: 06 August 2012, 20:22:17 »
Update,
Grim :(
Looks like you're looking at inline switch as previously suggested...  ...or turn radio up ;D
Shame whoever fitted the towbar saved a few quid going pattern.
m.ian
Re: Unknown wires
« Reply #29 on: 06 August 2012, 20:28:51 »
Yes very grim.
As suggested in line switch, will have a look again at wiring and wiring diagram at weekend!
Not easy though as colours on wiring diagram do not match whats on my car.
I know I should not have started this but its not going to get the better of me :)
Pages: 1 [2] 3  All   Go Up
