Author Topic: HID lights too low  (Read 6045 times)
Re: HID lights too low
« Reply #15 on: 06 January 2014, 18:05:11 »
is it possible to se that the front and rear sensors are working with the tech 2 ?
I have software
so if i connect it and take a drive, some of the sensors should be changing when going over a speedbump ?
and if so, what should the neutral value be ?
If I acutate the front sensor to the max, lights should be low ?
If I actuate the rear sensor to the max, lights should be high ?
You would be better to start a new thread rather than comment on such an old one  ;) ;) ;)
Have you checked that the adjusters have not broken? ..... they often do.  ;)
http://www.omegaowners.com/forum/index.php?topic=90638.0
P-son
  • South Sweden
    • Omega B 3.0 Caravan (FL)
« Reply #16 on: 06 January 2014, 18:43:12 »
ok, I am learn the old way to not open new threads in the same toppic if the if a good thread existing..
the only thing missing from this thread (that I found searching old threads) is what I asked for I think, so thats why i lifted it...
I just was out taking a spin with the tech 2/"My Naff Code Reader" connected.
Headlignht-Adjusters are working (tested with the program)
The front sensors are giving to low signal, 2.2 volts when stationary (basic setting is 3.7 volts the program says)
But the sensors are workning, say them give different value when driving.
Rear ones is OK 3.7v when stationary, and moving up and down when driving and braking.
Hope that I have time tomorrow to try switch the sensors betwen the 2 cars.
P-son
  • South Sweden
« Reply #17 on: 07 January 2014, 19:49:36 »
can someone confirm that the font sensor should read 3.7v on a V6 when stationary on plain ground ?
Have set the sensor to 3.6 (tini wini bit high) manualy and locked it there then adjusted the maonbeams max, still to low....
Car doesent look smached eather....
