Author Topic: Another CK-7W thread  (Read 7088 times)
Murph
  • Dartford, Kent
    • 2.5 Estate
« on: 31 July 2012, 13:06:19 »
I have read the other thread relating to the installation of the Nokia CK-7W bluetooth kit but have further questions that I couldnt figure from there.
Firstly, my car used to have a mobile phone cradle installed which plugged in at the drivers kick panel - can I use that plug to wire in this kit?
If so, does anyone know the pinouts for the plug - mostly I need to know where to splice in the speaker output so that it comes through the stereo speakers.
I'm using an aftermarket stereo so I will run the mute wire directly to the head unit.
Second - is there space behind the drivers kick panel for the control unit?
The rest of the wiring for it is pretty straightforward.
Cheers!
Re: Another CK-7W thread
« Reply #1 on: 31 July 2012, 20:01:27 »
If its had a phonekit, chances are, there will be the required 0v, 12v, ign 12v, mute and audio wires available. I would run a seperate Nokia mic up the passenger A pillar and mount near mirror.
Murph
  • Dartford, Kent
    • 2.5 Estate
« Reply #2 on: 31 July 2012, 20:20:23 »
Ok done that.  I used a section of the old car kit and splice the nokia loom directly into the wiring.  It powers up fine and I have got it paired but there is no audio through the car speakers. I hooked up an old speaker straight to the CK7W and that works.  :-\
Clearly Im missing something.
« Reply #3 on: 31 July 2012, 21:01:48 »
Are you getting radio to mute?
Murph
  • Dartford, Kent
    • 2.5 Estate
« Reply #4 on: 31 July 2012, 21:16:51 »
I havent connected that wire yet tbh.
I put the stereo on aux mode so that there was no conflicting sounds anyway.
  • Auckland
    • Mazda MPV
« Reply #5 on: 31 July 2012, 21:20:20 »
So you have an aftermarket radio fitted  :-\
« Reply #6 on: 31 July 2012, 21:23:37 »
Yes, my thoughts exactly.
Does this aftermarket stereo have a phone input?
Murph
  • Dartford, Kent
    • 2.5 Estate
« Reply #7 on: 31 July 2012, 21:29:54 »
Yes it's an aftermarket stereo  - I said that in the first post.   ::)
The problem I have is that the CK-7W was removed from it's previous vehicle by cutting the plugs off, so using a patch lead would be tricky too.
I guess what I need to know is how the patch lead is wired, so then I can duplicate that.
« Reply #8 on: 31 July 2012, 21:32:52 »
The mute wire should be present nearby. Presumably, you have wired phone audio into stereo phone input, which is likely to be different to the Aux input
Murph
  • Dartford, Kent
    • 2.5 Estate
« Reply #9 on: 31 July 2012, 22:22:44 »
I hooked it up to the socket behind the glove box which I now assume will only work with the original stereo.
So my plan is to solder it directly into a spare stereo loom, connecting the speaker output to both front speaker outputs.
Do you think that'll work?
« Reply #10 on: 01 August 2012, 18:10:18 »
Thats not recommended. At all.
Whilst it might not tune the stereo or carkit to channel smoke initially, it certainly won't do either of them any favours.
Does the stereo have a phone input?
Murph
  • Dartford, Kent
    • 2.5 Estate
« Reply #11 on: 01 August 2012, 20:03:52 »
Unfortunately not.
  • Auckland
    • Mazda MPV
« Reply #12 on: 01 August 2012, 20:19:46 »
The CK-7W comes with a loudspeaker that is intended to be mounted somewhere safe in the cabin.
The standard VX radios all have a phone input so the speaker isn't required. The safest way to use your CK-7W is to get hold of a suitable speaker and mount in in the passenger footwell.
Murph
  • Dartford, Kent
    • 2.5 Estate
« Reply #13 on: 01 August 2012, 20:59:13 »
I may just have to do that although I was hoping to not need it.
According to Nokia's website the CK7W supports and 'audio through the speakers' configuration. I know that I can use an autoleads adapter to do this, and it would sit between the stereo and the car's loom.
My thinking is that surely the autoleads adapter will do pretty much what I was going to do.
Murph
  • Dartford, Kent
    • 2.5 Estate
« Reply #14 on: 01 August 2012, 21:29:28 »
Well thanks for making me research further....
It seems that while I was right in that there is a patch lead, the lead incorporates a relay setup to allow the sound through.  It seems to me that that would be there to prevent a feedback surge into the head unit or handsfree.
Just gonna have to shell out for the adapter which is going to cost more than I paid for the hands free!
Cheers for the help chaps.
