Author Topic: Omega Air Suspension  (Read 1285 times)
megaelite
    • a car
« on: 31 July 2012, 13:53:57 »
the back end of my facelift elite sits a tad high or the fronts too low lol, i was speaking to a mechanic today and he said there is some sort of thing that sits on the front wishbones or there abouts which tells the car how its sitting on the road and thats what makes the suspension go up/down, is this right or not, is there away of getting the back of the car lower
Re: Omega Air Suspension
« Reply #1 on: 31 July 2012, 13:58:16 »
Well, he was close. ::) The sensor is on the rear subframe just by the diff. ;)
Worth checking it's still intact and connected to the rear trailing arm.
It's possible that the relief valve that lowers the air pressure in the shocks has failed. This is located by the pump, under the front offside wing.
megaelite
    • a car
« Reply #2 on: 31 July 2012, 14:02:05 »
when i first start the car you can hear the pump kick in and then go off, is something supposed to happen when the headlights get turned on aswell. he said the lights should go up or down with the hight of the car ???
« Reply #3 on: 31 July 2012, 14:38:26 »
It's normal to hear the pump when switching on the ignition.
Headlamps also level themselves if HIDs but this is a completely separate system so I wouldn't expect the levelling pump to activate in this instance.
