Author Topic: Pre-facelift ECC  (Read 2378 times)
JohnM
  • Newark on Trent
    • 2.5M Estate
Pre-facelift ECC
« on: 31 July 2012, 17:05:17 »
Hi.  Can someone with a Pre F/L check if their ECC does this - I might just have missed this previously:-
All working normally*, left & right temperatures linked / set the same (as more usual for me). Stop and switch off ignition; both temps go to " - - " for 1/2 to 1 second - then nothing as switched off.
Is it telling me something (lowish pres?) or do they do that sir ?
* Not ever so cold last week.
I_want_an_Omega
Re: Pre-facelift ECC
« Reply #1 on: 31 July 2012, 17:39:03 »
IIRC there is something in the book about this, possibly detecting a fault?
« Reply #2 on: 31 July 2012, 20:09:09 »
Its a fault notification
JohnM
  • Newark on Trent
    • 2.5M Estate
« Reply #3 on: 01 August 2012, 12:23:12 »
Bummer.  Thanks.
I_want_an_Omega
« Reply #4 on: 01 August 2012, 17:30:06 »
Hi John,
I'm not a million miles from you and have a spare ECC module. I'd be happy to post it over to you to see if it makes any difference.
Cheers - Rob
« Reply #5 on: 01 August 2012, 18:36:56 »
Hi John,
Cheers - Rob
Unlikely. It is more likely to be a sensor fault, or an actuator fault. Sometimes on the PFL unit, it can be an old stored code that upsets it, in which case, whilst a new ECU may clear this, its overkill for a simple code reset
plym ian
  • Plymouth, Devon
    • 2.0 insignia elite tourer
« Reply #6 on: 01 August 2012, 19:01:22 »
mine does it and always has since I've had the car about 3 years but the air con has never worked, hope this helps
JohnM
  • Newark on Trent
    • 2.5M Estate
« Reply #7 on: 02 August 2012, 22:24:17 »
Not too much :)  - mine worked/works (I thought).
Thanks Jamie, so a read the codes job - which readers can do this for the ECC ?
Rob, hold fire for me, I'll see what it is asking for first - hopefully a bit of TLC !
