Author Topic: ATF change due but should I?  (Read 7792 times)
Re: ATF change due but should I?
« Reply #15 on: 01 August 2012, 18:29:12 »
And dont forget to put foot on brake pedal when selecting gears if the handbrake is crap'ish  :y
Where did you get them very sturdy axle stands from Andy  ???
« Reply #16 on: 01 August 2012, 18:30:55 »
I would change it. Any DIII ATF should do, although I like Fuch Titan 4000. It should be the same as any other DIII, but I reckon it feels better than, for example, the Coma stuff. Of course, might be the placebo effect.
I used Coma for my ATF change ..........  ::) ::) ::)
So I see from the pic ;D
The Silver Bullet has Coma in currently, due to all the problems I had arond Newent last year.  I don't dislike it enough to change it, but given a choice, I'd use the Titan 4000. Not that much difference in price, either. Esp as Halfrods trade price on the Coma isn't that good ::)
I suppose I should try to blag a HAlford TC card  :-\ :-\ :y
The Coma ATF was from a local motorfactors.
« Reply #17 on: 01 August 2012, 18:32:49 »
What's a handbrake?  ::) ::) ::)
Axle stands are the larger stands from Machine Mart, they good, but a bit too big for most Omega jobs  :-\ :y
« Reply #18 on: 01 August 2012, 18:47:52 »
Yeah  ;D
Will have a look on M/Mart for prices then  8)
Webby the Bear
  • Northampton
    • 2000 (W Reg.) 2.5 V6 CD
RIP Paul Lovejoy
« Reply #20 on: 04 August 2012, 15:10:44 »
thanks chaps.... going to purchase this today. is this going to do the job...
http://www.wilkinsonplus.com/garden-woodcare-paint/cuprinol-fence-sprayer/invt/0236346/?htxt=vrRcIySO1tgSIS8aP3lSBSJij8gStjrzH2lO6bKB9GflzXbqc0mh7%2FL5DoTZYl0hrc%2BygtMoJWLC%0AeCPeLB9vgw%3D%3D
While I think that the sprayer idea is good, I just used a piece of tubing that was a nice 'screw fit' into the fill/level hole & threaded it up through the engine bay with a funnel at the other end of the tube. You just can't be at both ends of the tube at the same time.  ;D ;D
biggriffin
  • huntingdon, Hoof'land
    • It's Insignificant
« Reply #21 on: 04 August 2012, 15:13:02 »
me being good at upsetting pepes, are you changing both filters to.
  i use the wood spray route put 8ltr in pump it up and off it goes.
Hoof'land storeman.
Webby the Bear
  • Northampton
« Reply #22 on: 04 August 2012, 15:13:35 »
thats a good idea. thing im a bit worried about is getting air in there. but i suppose you feed the fluid through first, have a small bit coming out before you attach it? like with a needle injection?  :-\
i think, like you andy, i'd prefer to do it manually. wish it had a filler tube  :'(
RIP Paul Lovejoy
Webby the Bear
  • Northampton
« Reply #23 on: 04 August 2012, 15:15:12 »
thought there was only one filter?
i'm dropping both sumps though :)
RIP Paul Lovejoy
« Reply #24 on: 04 August 2012, 15:16:57 »
That's what the vent on top of the gearbox is for.  ::) ::) ::)
« Reply #25 on: 04 August 2012, 15:17:34 »
Correct!  :y :y
Webby the Bear
  • Northampton
« Reply #26 on: 04 August 2012, 15:18:45 »
cheers  :y i wont worry about air now  ;D
RIP Paul Lovejoy
biggriffin
« Reply #27 on: 04 August 2012, 15:19:21 »
 brain fade yup 1 filter. :D
Hoof'land storeman.
