Author Topic: 18 Inch Wheels - Opinions Please  (Read 5876 times)
Re: 18 Inch Wheels - Opinions Please
« Reply #15 on: 13 August 2012, 09:48:46 »
30mm (from standard, 15mm from LSC) is about the lowest you'd want to do on UK roads. Even then, when reasonably loaded, its a problem.  I was driving off a driveway the other day, but due to angle, couldn't go down the dropped kerb, and got beached. It wasn't a high kerb either.  Any load at all, I striggle with the speed bumps around here.
At 40mm (below standard), I'd be constantly wrecking the cats, exhaust mid sections near backbox, and diff.
In addition, with a 40mm drop (from standard), you'd have to spring it so hard to prevent suspension movement, it would be unbearable.
grannon_mv6
  • Hull
    • 2002 2.6 mv6
« Reply #16 on: 13 August 2012, 15:09:13 »
To be fair i really to get under and check whats on already as it does scrap the plastic spliter on the mv6 bumper when going over some speed bumps and that must only be what 20mm itself
Drive it like you stole it
PeddyP
  • Birmingham
    • Omega MV6
« Reply #17 on: 16 August 2012, 22:20:45 »
Mine's sat on a big fat set of 19's (265/35/19) , dropped 40mm... Had zero issues so far but it was like it when I bought it so don't know how the handling's been affected... Holds tight in the corners and still very torquey for a fully loaded beasty!!  :y
« Reply #18 on: 16 August 2012, 23:42:52 »
265...? Not on the front, unless there are some very odd offset issues in your favour...?
« Reply #19 on: 17 August 2012, 08:57:57 »
If the offset was enough to clear strut, at 40mm drop, there would be tyre/wheelarch contact.  I suspect the 265s are on the back, and 235 or 245 on the front :)
« Reply #20 on: 17 August 2012, 10:09:59 »
Actually, yes, quite so. I know, and don't ask how I know (;D)that my 265 rears will not physically fit on the front. Not even close ;D
Oh, those will be the REAR tyres then. :-[ ;D
« Reply #21 on: 17 August 2012, 10:17:11 »
Should have gone to specsavers Kwik Fitup. ;)
« Reply #22 on: 17 August 2012, 10:27:26 »
Yes it's an easy mistakeadamaker. Even Micheldever managed to cock it up. 245 on a nine inch rim...? I think not! ;D
« Reply #23 on: 17 August 2012, 11:52:12 »
I don't know.. some of the retards driving around these days seem to like that look... Just pump it up to 60PSI. ;)
PeddyP
  • Birmingham
    • Omega MV6
« Reply #24 on: 18 August 2012, 13:06:26 »
Oops! Haha, yes 235's on the front. Should be back on the road Sunday after having both heads done and rear arches fixed  ;D
Page created in 0.034 seconds with 16 queries.
