Author Topic: How much is a windscreen  (Read 12376 times)
Re: How much is a windscreen
« Reply #45 on: 04 August 2012, 16:02:19 »
This trim is probably the frame that goes around the screen that the rubber moulding then clips into :y
It's called the trim seat, and now comes in four parts, top, bottom and two sides :y
If you pull the rubber trim away from the screen, you see it underneath :y
£40 sounds alot for a pattern set. All four parts from VX were £60, with discount, they fit perfectly as you'd expect  :y allow a week though, as three pieces are in stock in the UK, but the drivers side pillar one is somewhere in euroland ::) the rubber trims are £50 from VX and should be next day :
oh right thanks for that, bit daft saying you may need them when the window is out, thats with autowindows. there was one omega windows £130 with them, autowindows want £130 for the window + £40 for the inner trim. but omega windows only have green tint one's in and mine is blue. dont like the idear of green on a blue mig.
The trim seats and the rubber trim all get fitted to the glass before it gets fitted to the car :y they might need them if the old ones are distorted, or damaged when removing them, hence not knowing until the screen is out :y
« Reply #46 on: 04 August 2012, 16:04:54 »
just found this if any one is intrested facelift windscreen http://www.ebay.co.uk/itm/Omega-B-Facelift-00-03-Complete-front-windscreen-from-Elite-model-Derby-/160856137297?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item2573c5de51
All screen are the same shape, pre and post facelift, saloon and estate :y only difference might be the mirror mounting :-\
Pages: 1 2 3 [4]  All   Go Up
Page created in 0.009 seconds with 18 queries.
