Author Topic: 3.2 running rough  (Read 4480 times)
Re: 3.2 running rough
« Reply #15 on: 03 August 2012, 14:23:18 »
Pop out the bank1, drivers side coilpack :y
You're looking for any of the following:
1. Evidence of water or oil in the plug wells, especially the middle one, plug 3.
2. Cracking or corrosion on the visible surfaces of the coil pack.
3. Loose plugs, again plug 3 in particular.
4. Any sign that the wiring to the coil pack plug is breaking down, either brittle or corroded.
Solutions, see maintainance guides for how tos:
1. If water, dry out and also re seal the scuttle.
     If oil then the cam cover gaskets need doing along with the breathers.
2. Replace the coilpack, they can look pretty shabby and be fine, but if alot of rust and     cracking replace it.
3. Tighten the plugs.
4. Last resort this one, and for now unlikely, new loom.
For peace of mind if you find 1,2 or 3, check the other side :y
Kendo1690
  • Liverpool
    • 52 3.2 Elite,08 Zafira150
« Reply #16 on: 03 August 2012, 14:41:28 »
Thanks everyone getting sorted Saturday,is it ok to drive a few miles ? :y
« Reply #17 on: 03 August 2012, 14:44:07 »
The light might annoy you :-\ but unlikely to kill it :y
Fwiw mine has been on so long that the bulb has blown :-X
« Reply #18 on: 03 August 2012, 14:48:15 »
Mine has done 119000,the pedal test came up 0300 can anyone shed any light, :y
0300 random/multiple misfires,what could this point to,
Also 0303 number 3 cylinder misfire.... :y
Kinda points to pot 3 then  :)
or 1/3/5 coil pack  ::)
Yup, but better off starting with the plugs first  :)
Kendo1690
  • Liverpool
« Reply #19 on: 04 August 2012, 09:44:43 »
Managed to get 1,3,5 coil pack from europarts for just under £82,Bosch as well,there is an online code of "winner30" available if you spend £100 and over,click and collect service,should of been nearly £117 so to get for £82 including vat IMO is a great saving..... :y
Kendo1690
  • Liverpool
« Reply #20 on: 04 August 2012, 09:46:07 »
Sorry the code gives you 30% off... :y
Kendo1690
  • Liverpool
« Reply #21 on: 04 August 2012, 16:52:45 »
Many thanks everyone,pedal trick worked,1,3,5 coil pack full water number 3 cylinder the worst which code 0301 suggested,new coil pack fitted,running like dream again,cheers for the help again.Fantastic website,proud to be a member of OOF ........ :y :y :y
Kendo1690
  • Liverpool
« Reply #22 on: 04 August 2012, 18:37:27 »
Code 0303 not 0301
Page created in 0.025 seconds with 20 queries.
